I have a set of BMR rear lower control arms (spherical at one end and poly on the other) and have recently noticed a hollow noise when going over bumps at a low speed (mainly the right side). I also have their adjustable rear panhard bar with Roush lowering springs. Anyway, I double-checked every bolt tonight and everything is tight.
It sounds like the noise is coming from the trunk area, but i don't have anything in there so it's probably reverberating from somewhere else. I think it's the e-brake cable when/if it hits against the control arm. Is there somewhere I can tie-wrap it to or do you have any suggestions to keep it from hitting the arm? It's currently resting against the arm. I was thinking about taking some duct tape and wraping it around the area of the cable (to try and minimize potential noise).
Anyone else have the BMR (or other aftermarket) control arms and notice a similiar noise?
Where ya' been? (PM me).... Good point. Real quick? on the BMR LCAs - Don't they use Energy Suspension bushings? I would find it hard to believe this is occurring unless there have been some real bad batches "cooked", they have been hanging around the shelf for 5 years or the Stang in question has been driven with such lateral load that "poly bind" ripped the bushings (well, improper torque on the bolts and continual slop grinding them could do it as well).
Your thoughts?
