  • 2005 - 2009 Specific Tech
BMR Lower control arms
  • Thread starter Thread starter Fast05
  • Start date Start date Feb 18, 2006
Fast05
409
Corpus Christi, TX
Feb 18, 2006
  • Feb 18, 2006
Hey guys,
I was in the middle of installing my new bmr lcas today and what i thought would be a relatively simple process i got hung up on something and wanted to know if anyone else has had this problem. The bold for the back end of the control arm does not fit through the control arm itself. The instructions say to use factory hardware, i shouldn't have to go buy new bolts ? This does not make sense, any ideas?
Thanks in advance
05 Horseplay
Puyallup, WA
Feb 18, 2006
  • Feb 18, 2006
Fast05 said:
Hey guys,
Thanks in advance
I also have the BMR LCA with poly bushings on my 05. The only issue I had was the sleeve wasn't cut correctly (just fixed that about 30 min ago). The stock bolts should work - you may have some edges left in the sleeve from when it was cut. If not, maybe the wrong sleeve was sent.
Hope this helps
G
gp001
4,401
So. Cal.
Feb 18, 2006
  • Feb 18, 2006
Fast05 said:
Hey guys,
Thanks in advance
They sent you the wrong sleeve. I had the same issue. contat them and they will send you replacements
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Feb 18, 2006
  • Feb 18, 2006
what are you doing about the e-brake cable?
Fast05
409
Corpus Christi, TX
Feb 18, 2006
  • Feb 18, 2006
E brake cable was actually pretty easy...just removed the little clip that holds it in place, and it comes right out...i have zip ties to hold them to the new control arms. Only difficulty was not knowing I needed to release the e brake in order to put everything back, but it only took about 5 minutes to figure that out. If they had sent me the correct ones the whole thing should have take no longer than about 30 - 45 minutes. Guess I'll call them up monday morning...
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Suspension J&M lower control arms side specific?
  • Andresquintana.mma
  • May 18, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 18, 2024
Andresquintana.mma
9
Control arm length
  • 90FoxLX
  • Dec 27, 2023
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2023
90FoxLX
9
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
