Body cart/Dolly
1/2fastback
17
Texas
I'm needing to remove the front suspension and rear end for a trip to the media blaster. Has anyone made a body cart/dolly/etc. to move the car around while the suspension is off? Any pics/suggestions/help is appreciated.
I have a rotisserie, but I've seen some carts made. How is the media blaster going to handle the body? Does the cart need to be high or can it be low?
If it were low, you could probably make some stuff out of 4x4s and casters, but you can get into a rotisserie for a couple hundred more I think.
I made a body dolly out of 2 X 2 steel tubing. I made short uprights to where the lower control arms mount and to where the front of the rear springs bolt to the body. I made it so the body would be as level as possible, but I also went slightly overboard and made the chassis mounting points with screw type adjusters so the body could be further leveled it need be. I used some fairly heavy lockable casters on the front and solid wheels on the rear. Sorry i don't have any pics and it is currently at my body guys place which is an hour away. If I get over there soon I will take some pics.
Mine is made from 2"x2" steel tubing. The mounting points are the lower control arm bolts (Front) and the front spring eye (rear). Works great.
My set up is very similar, except I didn't go as far forward; stopped at the firewall so I have enough room for my front suspension upgrade. I found some 3x3 ~3/8" steel tubing at a steel yards junk pile. Worked out great. Oh... make sure you get good casters that can support the weight of the car. <--- learned lesson on that one :rolleyes:
Well, Accessible Systems has body carts from $275 to $650:
http://www.accessiblesystems.com/bc01.php
$650 is where their rotisseries start at:
http://www.accessiblesystems.com/bul/price_list.php
They're in Johnson City, TN, you don't say where you're at.
AutoTwirler is in Gosport, IN but they only make rotisseries and start out at about $750:
http://www.autotwirler.com
My rotisserie is a WhirlyJig, they start out at $895 and are, I consider, the Cadillac of rotisseries, mine is the Model Standard which is $1250, but I picked it up locally from a guy who had used it on one restoration of a '60 Starliner for $500:
http://www.whirlyjig.com/
Then there are the type I spoke of before:
http://www.harwoodperformance.bizland.com/1941buick/062903.htm
http://www.jalopyjournal.com/forum/showthread.php?t=143110
