Bog and Launch
  • Thread starter Thread starter 86bluecobra
  • Start date Start date May 12, 2005
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 12, 2005
  • May 12, 2005
Ok im sure many of you who have been at a track to race know about this. I am wondering how to get around it. I tried a 4500rpm launch with slicks and ran a 13.07 1/4 mile time with a 1.8 sixty foot time. but the car bogged of the launch. i had a slew of 1.9 and 2.0 sixty foot times with various bogs. I finally twisted a axle shaft apart. how do i get rid of the bog? i realize if i want to launch much higher in the rpm range im going to need a built 8.8. however i dont have the cash for that right now. i dont bog with nos and run 1.6 sixty foot times
cleanLX
976
537
144
May 12, 2005
  • May 12, 2005
You run 1.6 60's on N2O but you are afraid to up the launch rpm when N/A?
That does not make sense to me.
At any rate, up your tire pressure so you can roll the slicks over, or up the rpm to achieve the same thing.
Bog comes from dead hooking... you want to roll the tires over, or, slip the clutch on the way out.
Good luck.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
May 12, 2005
  • May 12, 2005
Good luck.
I agree with everything he said!
silverstripes
81
monroe, LA
May 12, 2005
  • May 12, 2005
Bog mainly comes from launching to high rpm. Sounds wrong but its true. Usually the best launch without bog will be around 500rpm (can range due to flywheel weight) above peak torque which on a mild cam on a 5.0 will usually be from 2800 to 4000. If you choose to launch too high the engine will pull down way below peak torque and bog. Whereas if you launch just slightly above peak torque it will pull down to peak torque and try to turn the tires as hard as possible. Hope this helps.
silverstripes
81
monroe, LA
May 12, 2005
  • May 12, 2005
Oh yeah bog can also be a from a series of other problems that are related to proper tuning of the car. (fuel press., injector size, fuel volume, ect.)
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 12, 2005
  • May 12, 2005
thx guys didnt think of upping my air pressue on my slicks i was running 12 psi. its not that i am scared of launching at a higher rpm i tried launching at 2500 rpm and went up in 500 rpm intervals to 4500 rpm. it just didn't seem to help. i wondered if there was something i was missing. I'm not a hard core drag racer i only race 2 or 3 times a year. what psi would you recomend trying when i am N/A
T
tom2001gt
292
Delran N.J.
May 12, 2005
  • May 12, 2005
I would put the tire pressure at 13 psi and leave at 5500 I did that with a stock rear and axles with no problem. 302's don't have tourque like a 351 you need to leave hard.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 12, 2005
  • May 12, 2005
thx ill try 13 psi!
silverstripes
81
monroe, LA
May 15, 2005
  • May 15, 2005
It doesn't matter if a 302 has less torque. It will still have a peak torque and it is not at 5500 unless you are blown or have a hell of a built engine that turns ungodly rpm. Once again the best launch is generally around 500rpm above peak torque and if you are still bogging then you have another problem probabaly fuel related. As for the tire pressure that will not cause a bog. The last thing i would want to do is spin the tires or slip the clutch we aren't talking top fuel here. Check out the NMRA and see how many guys want to slip the clutch or tires. Thats a joke.
Once again peak torque for any engine is where the tires will be trying to turn as hard as possible this is where you want to be during a launch regardless of what engine you are running.
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
9
1/8th Mile Time?
  • 93lx308
  • Jan 12, 2018
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2018
RangerJoe
Fox T5 To Aod Conversion
  • 86GTVert#2
  • Jun 29, 2016
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2016
86GTVert#2
M
Rocker Install, Pushrod Length Problem?
  • mostsmooth
  • Nov 8, 2015
  • 1994 - 1995 Specific Tech
5K
1994 - 1995 Specific Tech Nov 16, 2015
revhead347
1/4 Times New To Me Gt
  • fox04
  • Jul 23, 2013
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 23, 2013
Sharad
