bogging down, running rich maybe?
  • Thread starter Thread starter stockstang23
  • Start date Start date Jun 7, 2005
stockstang23
41
  • Jun 7, 2005
Well i just picked up a 95 5.0 hte mods are as follows thus far.
Pulleys
CAI
70 MM TB
1.7 RRs
9MM Plug Wires
Crane Fireball ignition
O/R x pipe
Flowmaster 40 series cat back exhaust
3.73 gears in the rear
FRPP fuel pressure regulator
Holley 190LPH in tank fuel pump.
now when i get on the gas all the way...its very "bogy" like its running realy rich.
but since its a new car and im former ls1 owner..i dont knwo how to check to know if its REALY running rich...and if it is how would i change it? and how would i change while makeing sure i dont run lean?
any help would kick ass guys thanks
J
JJPA
59
Lancaster,PA
Jun 7, 2005
  • Jun 7, 2005
the best way to check is to go to a dyno with a wideband A/F gauge and check it that way. I bought my 5.0 and it already had a fuel gauge on it so im not sure if there is a place on your FPR to add a gauge. But even if you go to a dyno you can get your pressure right, and your a/f right so you know your not too rich or lean, and you can also see what you are putting down.
stockstang23
41
  • Jun 7, 2005
wouldent that cost like $500 ? or would they no consider that a tune when just adjusting the A/F?
stockstang23
41
  • Jun 8, 2005
ok well check the fuel pressure. it seems to be ok, around 38-42 psi.
anything else it could be?
D
darkarrow
31
  • Jun 8, 2005
you should pull your MAF sensor and check to see if it is clogged with dirt, that was my problem. if it is clogged, electrical cleaner should clean it with some q-tips, but be careful, dont want to pay another 100 for that part.
MagnaflowGT
73
  • Jun 8, 2005
and dont forget to check the plug wires and the bolts on the egr valve. thats what caused mine to bog
stockstang23
41
  • Jun 8, 2005
lets see here..tires plus suggested i do Cap,Rotor, and wires they did a diagnostic test and determinded that to be the problem...they told me something was hitting 1.2 Volts, and that when they sprayed water on something th car nearly dies.
anyway ill order the wires and rotor and **** tommrow and do that my self.
But do you guys agrea that this COULD be the problem?
stockstang23
41
  • Jun 8, 2005
ups for good mesure.
J
JJPA
59
Lancaster,PA
Jun 14, 2005
  • Jun 14, 2005
damn where i live there is a dyno that does 4 pulls for 40 bucks with a wideband. Where are you from?
Curse
791
El Paso, TX
Jun 14, 2005
#10
  • Jun 14, 2005
  • #10
sounds like a dirty or bad MAF to me.Good Luck
HISSIN50
34
129
Jun 14, 2005
#11
  • Jun 14, 2005
  • #11
You would be hard pressed to run rich with a stock puter in a 94-95 (sans Cobras, which came with a nice tune). I would be lookin elsewhere - and it sounds like a good tune up is in order. SHould you choose to do it yourself, you will find ample assistance in here and learn a bit about the car.
Good luck.
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
94 cobra possible idle issue?
  • Bowen94
  • Feb 15, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Feb 16, 2024
L
P0122, running rich - an easier solution?
  • lparsons
  • Jul 3, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- Sep 8, 2023
weendoggy
97 Cobra Bank 2 Running Rich
  • 91LX302
  • May 29, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Jun 1, 2023
91LX302
