Bogging Issue
  • Thread starter Thread starter fastford87
  • Start date Start date May 19, 2009
F
fastford87
18
Ringgold, GA
May 19, 2009
  • May 19, 2009
Ive got a 87 LX coupe 5.0 5 spd and I am having this problem with the car stumbling or bogging down when it reaches 4000 rpm in any gear. It has a 70mm throttle body 24lb. injectors and mass air on an HO intake and stock fuel pump . The car dies then comes back when you let off the gas. I have a trick flow street burner intake (not on yet) but do you think if this was on, it would stop stumbling? Any help would be grateful. Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 19, 2009
  • May 19, 2009
Did you build this combo yourself or buy it off someone else? Is this a real Mass Air conversion or did someone just hang a MAF in the intake plumbling? The 87 model 5.0 Mustangs did not come with Mass Air from the factory. What model computer is in the car?
A stock engine does not need 24 lb injectors. The MAF will need to be an aftermarket item designed to work with 24 lb injectors or you will need a custom dyno tune and chip to make the 24 lb injectors work properly. A mismatch between the stock tune and the 24 lb injectors will cause all kinds of strange problems.
BigDanTheMan
63
San Francisco, CA
May 20, 2009
  • May 20, 2009
when i feel sluggish i re-oil the ol' k&n and re-gap and check the plugs.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
May 20, 2009
  • May 20, 2009
That sampling tube inside the MAF has to be a 24lb injector sampling tube. C&L makes these for about $40. Make sure to call and ask if it's to fit a stock MAF I'm not sure if it's different than their aftermarket fit.
If your MAF is correct, I've seen this stumbling happen for a couple of reasons...
1) Distributor is bad (or at least the little sensor deal in it). I've also seen an MSD dizzy do this for an unkown reason.
2) Vacuum is wrong, but that is usually at lower RPM
3) Adjustable fuel pressure regulator is set wrong
4) And as stated above, a reoiled K&N will sometimes slosh it's oil on the wire inside the MAF. I actually had that problem on a GMC truck once.
Also check the dizzy cap and make sure the contacts are clean. When's the last time you had a tune up?
F
fastford87
18
Ringgold, GA
May 20, 2009
  • May 20, 2009
I bought it this way and I do believe he or someone else put the MAF sensor on. It has the plug for the sensor , when I unplug it it still runs the same. I did find the metering sticks at summit. I dont think it has an adj. pressure regulator Ill have to look tomorrow. Do you think that that might be part of it if its losing pressure along with the metering stick being stock? Let me know if I should take the MAF off or keep it on or something. I dont know much about Mustangs, my first one, I'm actually a Chevy man Thanks for the help
C
cheese_05_70
58
IL
May 20, 2009
  • May 20, 2009
Check with a voltmeter with your key on not running and see what your throttle positon sensor voltage is through out the throttle range. Use the black for ground I believe it is the wire next to the black one. One wire will be a constant 5 volts the other will increase with the throttle. It should also be set around 0.95-98 at idle I believe.
Your 24lbers are a little much for a stock motor. And do you have an aftermarket mass air meter calabrated for them. The stock meter you cannot change out tubes or anything. Only on an aftermarket C&L you can do that.
I have an HCI 306 w/ 24lb injectors and the only way I could get it to run right even with a calabrated mass air meter was with a tune. It kept loading up my #5 cylinder and I dont know why and neither does my tuner. But the tune fixed it.
F
fastford87
18
Ringgold, GA
May 21, 2009
  • May 21, 2009
If I get a new MAF should I get a 73mm or 76 mm sensor? I have a 75mm TB
C
cheese_05_70
58
IL
May 21, 2009
  • May 21, 2009
I would go with a Pro-M calbrated for 24lb injectors. I had a C&L 73mm and it ran like s****. Put a 75mm Pro-m and it ran stronger but with my setup I still needed a tune to get the full potential out of it.
Did you check the throttle postiion sensor?
F
fastford87
18
Ringgold, GA
May 22, 2009
  • May 22, 2009
I believe I have a C&L the intake tube is C&L and it looks like the pic on CJ pony parts how do I tell what Ive got? Does the sensor on top that screws on need to be changed or just the tube? Please let me know, Thanks
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 23, 2009
#10
  • May 23, 2009
  • #10
The MAF body and sensor are designed to match each other. Type A sensor works with Type A bodies. Therefore you can't swap sensors between different part number MAF bodies and maintain proper calibration. However, the bodies and sensors are not necessarily calibrated together to create a precision matched pair.
The output voltage of the MAF is a function of the air flowing through it. The MAF itself does not know about injector sizes, nor does it care. All it sees is that an increase in airflow means a corresponding increase of MAF output voltage. Altering the design of the MAF body can alter the flow past the sensor.
The OEM ford system was designed to use internal computer tables to match the voltage output of the MAF to a calculated injector turn on time. The injector table uses only one size injector in its calculations. This is a much more accurate means of determining the engine’s fuel requirements. Using a different MAF than the one the computer was designed for can upset the computer's calculations and the air/fuel ratio.
What aftermarket MAF’s do is try to fool the computer by either changing the amount of airflow over the stock electronics (C&L method) or by altering the sensor itself (Mass Air Systems method). The goal for both methods is to change the output voltage of the MAF so the computer calculates new data that is used to vary the pulse width sent to the injectors.
Unless I am mistaken, C&L tells you to use the MAF sensor that came with the original car. On a 89-93 5.0 Mustang, that was a E9ZF-12B579-xxx
F
fastford87
18
Ringgold, GA
May 23, 2009
#11
  • May 23, 2009
  • #11
Thanks that was helpful.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
