After my longtube install, I was at 100% duty cycle on my Cobra pumps and my A/F was leaning out after 5200 rpms. So I switched over to dual focus pumps with a wire mod. Now, after retuning I'm at 80% duty cycle and A/F back to normal (11.5-12:1).
However I'm noticing a new problem:
When I had the Cobra pumps in there (stock tank w/ modified basket), I noticed that if I had less than a 1/4 tank of gas, the engine would occasionally bog down or hesistate while making turns. I heard that this was normal due to the unbaffled tank design, and so this was no big deal to deal to me.
Now with the twin focus pumps, the bogging problem seems to be worse. It seems to happen with fuel levels below 1/2 tank, rather than a 1/4 tank. \
Even worse, I'm getting the same type of hesitation at the dragstrip, with ~ 3/8 tank of race gas just as I launch the car. Coming right out of the hole at about 5000 rpms, the engine will momentarily hesistate, costing me about 0.2 s 60ft time. Adding a couple gallons of gas will eliminate the problem for 4-5 runs, then it will return.
I wouldn't really complain if it was pump gas, because I'd just fill it up. However, I use a race gas tune at the track, and it will be pretty damn expensive to fill the tank with race gas.
My question: Do you think this bogging problem at the track is tank related?
I ask because I'm thinking about swapping to the cobra tank, but I don't want to spend all than money ($700), if the bogging problem is not tank related
