BOLT PROBLEMS!!!
  • Thread starter Thread starter foxstang9050
  • Start date Start date Feb 23, 2006
F
foxstang9050
158
El Doarado Hills, CA
Feb 23, 2006
  • Feb 23, 2006
I was trying to pull one of the bolts off of my bellhousing, and the sone of a bitch was so damn tight, plus my stupid mistake not having a wrench on good enough, i rounded off the bolt.... tried many things, it keeps rounding... stopped before i completely rounded off but its pretty bad. What can i do???
seijirou
2,417
DFW
Feb 23, 2006
  • Feb 23, 2006
Tighten down the bolts on either side of it and loosen all the other bolts. Torch that bolt and get it hot, then try to get it out. You may need to resort to vice-grips if you can get them on. If not, last option is to get a socket that just barely doesn't fit, and smack it on.
F
foxstang9050
158
Feb 23, 2006
  • Feb 23, 2006
And for someone who doesnt have a torch... will a simple lighter do anything?
88GeeTee
49
Ft. Lewis, WA
Feb 23, 2006
  • Feb 23, 2006
no...you need the heat a torch produces...a lighter gets nowhere near as hot...
Josh
bill302
2,131
alabama,gadsden
Feb 23, 2006
  • Feb 23, 2006
a small pipe wrench works great in these cases if it will fit in the area where bolt needs removing or use vice grips. heat as seijirou previously stated and spray with pb blaster allow time to penetrate and attempt to remove with pipe wrench or vice grips... good luck...
bill302
2,131
alabama,gadsden
Feb 23, 2006
  • Feb 23, 2006
you can purchase a small bernzomatic propane portable torch at any parts store for approx $15 or less.which bolt is it top side or bottom....
F
foxstang9050
158
Feb 24, 2006
  • Feb 24, 2006
Its on the bottom
bill302
2,131
alabama,gadsden
Feb 24, 2006
  • Feb 24, 2006
you can get a pipe wrench on it at that location but i would use some heat and pb blaster to free it up to keep from breaking bolt....
Saleen0679
876
24
49
Yakima, WA
Feb 24, 2006
  • Feb 24, 2006
You can get a bolt extractor kit. They looks like sockets with agressive teeth on the inside. They are made for bolt heads that have been rounded off. I know Sears carries them.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Saturday at 4:37 PM
Classic Mustang Specific Tech Sunday at 5:17 PM
AlexM556
A
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
