  • SN95 4.6L Mustang Tech
Boost Gauge: Electrical or Mechanical?
  • Thread starter Thread starter AmBo
  • Start date Start date Apr 26, 2006
1 of 2 Next Last
AmBo
1,027
New Jersey
Apr 26, 2006
  • Apr 26, 2006
I'm being told mechanical is the way to go. Just wanted to confirm. Thanks!
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Apr 26, 2006
  • Apr 26, 2006
mechanical is cheaper. it's easy to install, and i see no reason why an electronic version would be any better. you surely can't go wrong with the mechanical gauge.
sgarlic
3,085
Apr 26, 2006
  • Apr 26, 2006
The only reason I would use electronic gauges is for things that would involve liquids being plumbed inside the car (oil, coolant, fuel, etc.)
speedfreak98r
Banned
Jan 31, 2006
Houston Area
Apr 26, 2006
  • Apr 26, 2006
DBMSTNG the pic in ur sig is truly f'd up. I despise spiders, and the thought of biting into one like that, and tasting the....the...th.
the98stang
2,408
Clovis, CA
Apr 26, 2006
  • Apr 26, 2006
The electonic gauges are no better than the mechanical gauges. Autometer makes some good, cheap gauges.
AmBo
1,027
New Jersey
Apr 26, 2006
  • Apr 26, 2006
I'm going to go with some cobalt guages. Mechanical Boost but I don't know what 2nd guage to go with! I was thinking fuel but they are like $200. Oof! What else would I need aside from boost being blown?
the98stang
2,408
Clovis, CA
Apr 26, 2006
  • Apr 26, 2006
oil pressure gauges are always very handy. You should also get a water temp gauge, and A/F ratio gauge
the98stang
2,408
Clovis, CA
Apr 26, 2006
  • Apr 26, 2006
the98stang
2,408
Clovis, CA
Apr 26, 2006
  • Apr 26, 2006
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Apr 26, 2006
#10
  • Apr 26, 2006
  • #10
Mechanical boost and electric fuel pressure are a MUST with S/C'd rides. Too much money riding on that engine and you'd rather spend the $200 on a gauge that can save you several grand in the long run IMO....
TweekedGT
1,274
Alberta
Apr 26, 2006
#11
  • Apr 26, 2006
  • #11
I have an electric Boost gauge, Autometer C2 but it is actually mechanical. You have to plumb into a vac line with a t fitting. I don't know if there is an actual true electric boost gauge out there.
BennyBlown2v
1,233
Carmel, INdiana
Apr 27, 2006
#12
  • Apr 27, 2006
  • #12
Yeah, there are. There is a separate sending unit (sensor) which you put into the intake/Tee off vaccume line for full electric gauge, then wires from that go to the gauge. The electrical connection on our gauges (i have the same one) is just for the light.
AmBo
1,027
New Jersey
Apr 27, 2006
#13
  • Apr 27, 2006
  • #13
So if I get two guages, I should go with Boost/Vac (mechanical) and Fuel Pressure (electrical)? My friend says Oil Pressure is more important that Fuel Pressure. Thoughts?
Fuel Pressure is like $200. Ouch...
R
RoadconeTuning
458
Upstate, SC
Apr 27, 2006
#14
  • Apr 27, 2006
  • #14
those a/f guages are useless... nothing more than a light show... but im going to get one because i think they look funny
AmBo
1,027
New Jersey
Apr 27, 2006
#15
  • Apr 27, 2006
  • #15
Who said ANYTHING about air/fuel? And why the hell would you get an a/f guage on a N/A setup? Is money burning that much of a hole in your pocket?
Firemanz
4,105
San Antonio, TX
Apr 27, 2006
#16
  • Apr 27, 2006
  • #16
Oil pressure IS important, but remember, there's already one in your stock instrument cluster. At least you can see what your pressure is now.
Your vehicle doesn't come with a fuel pressure gauge so there's no way to see if your pump's giving out or if it's clogged while under boost.
No fuel under boost = BOOM.
AmBo
1,027
New Jersey
Apr 27, 2006
#17
  • Apr 27, 2006
  • #17
Why do you gotta scare me?
What gauges are you running bro? I'm leaning towards boost and fuel. Then down the road I can get oil pressure and wideband a/f. That's $600 of gauges right there!
Firemanz
4,105
San Antonio, TX
Apr 27, 2006
#18
  • Apr 27, 2006
  • #18
Not trying to scare you homie, just don't want you to learn an expensive lesson. I have electric fuel pressure, mechanical boost, and an A/F gauge I got for $10
I do plan on taking out the A/F and getting an oil pressure gauge eventually. It's not high on the priority list though.
DropTopPony
Noob Slayer
2,570
south jersey
Apr 27, 2006
#19
  • Apr 27, 2006
  • #19
cheap, cheap, cheap....is that the noise your hearing under your car?
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
Apr 27, 2006
#20
  • Apr 27, 2006
  • #20
I run a mechanical oil, coolant and FP gauge setup on my Fox. I prefer the mechanicals over the electrics due to cost and range of needle sweep. The mechanicals range is greater allowing you to be more precise with your measurements.
I have my mech FP gauge out on the cowl, i prefer it this way but the oil and coolant temp gauge are in an A-pillar.
Despite what everyone says, no coolant comes inside the car on a mechanical coolant gauge. A probe is inserted into the intake and capillary tubing transmits the heat back to the gauge.
As for mechanical oil pressure, run braided stainless line and you shouldn't have a problem. Sure it's expensive, but the cost of 6 feet of braided line plus a $40 gauge is still cheaper than the $200 or so some of these electrical gauges go for. But this is all my preference.
PS. the factory oil pressure gauge is basically an idiot light. It points to the middle if you have pressure or 0 if you lose it. WHat i like about the mechanical gauge is that you can see every little twitch of pressure. It helps you because you can tell instantly if something is wrong if you see the pressure slightly lower than it usually is one day vs waiting for it to completely fail on you before the factory gauge shows you. The only 4.6L with an actual REAL oil pressure gauge in the dash are the '96 Cobras.
1 of 2 Next Last
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
