boost gauges
Stangshark
50
Indiana
I am wanting to install a boost gauge inside my car using the autometer center gauge pod. My question is with the mechanical boost gauge I heard you have to drill a hole in the dash. However, with the electrical you do not have to drill any holes. Is it true that I would have to drill a hole to make the hose fit into a mechanical gauge??
If you are determined you can run the wires and/or vacuum line through the firewall and under the dash. Then you can force fully squeeze them through the seam of the defrost vent/dash pad and out throuigh the defrost vent. No holes drilled. I have three gauges wired this way in my dash pod.
