boost on a stock block
There are a lot of variables here. What compression ratio, which heads / cam, main support or no, forged pistons, how much RPM, type of driving, how much rwhp your looking to make etc...Generally if you make more than 450-500 rwhp with a stock block you run the risk of breaking it. I would say 8 psi or so to be safe. Also a blown 347 will most likely require a complete fuel system to be safe.
Yeah it will work, what cc's combustion chambers do you have?? WHats the final comp ratio? I would suggest buying the girdles for the engine, And make sure you have a good tune. once you start pushing over 500 on a stock block the risk of breaking goes up, However i have seen 600 + on a stock block that they have ran for a year with no problems...so its a gamble.
