  • 2.3L (N/A & Turbo) Tech
Boost Problem...will anyone ever have the answer?
  • Thread starter Thread starter TurboCoupeWHITT
  • Start date Start date Sep 17, 2004
TurboCoupeWHITT
46
Ashland,Ky
Sep 17, 2004
  • Sep 17, 2004
ok my parents had a 87 turbo coupe with a five speed and the turbo blew out in it and they werent doing nothing with it ..... it had been sittin for about 4 to 5 years....and i decided i was goin to buy the factory turbo and swap it in ...so i bought the car off of my parents swapped it and .... changed all the vacum lines, belts, oil, oil and fuel filters, plugs everything........
got a boost controller off of a friend.. i know it works cause he was boost 25 psi in his talon and he got an elctronic boost controller and gave me his old one ...... when i boost 10 psi my car runs fine no problems in any gear.......then when i turn the boost to 15 the car bucks and **** like its being cut from fuel or the timing is being retarded.... so i checked my injectors replaced my o rings to my injectors and fule filter...... and it still cuts out and jumps when i try to boost above 10 psi.....anyone got any ideas????
351wcoupe
1,811
Manhattan, Kansas
Sep 17, 2004
  • Sep 17, 2004
If you suspect its pulling timing.
1. check the timing w/ and without the SPOUT connected.
2. disconnect the knock sensor
My opinion......
If it doesn't do it at 10 but does over that check to make sure your hose clamps for the intercooler aren't leaking.
N
NY Eric
67
Carmel NY
Sep 17, 2004
  • Sep 17, 2004
What did you tune up with. Unless you used Motorcraft parts you are asking fro probs in the turbo cars. Also check your timing with the spout out you should be 10DBTDC.
N
NY Eric
67
Carmel NY
Sep 17, 2004
  • Sep 17, 2004
QUOTE]
Careful on this one yes it is a good Idea to check but Headgaskets go quick if you dont know what you are doing. Just My 2 cents.
351wcoupe
1,811
Manhattan, Kansas
Sep 17, 2004
  • Sep 17, 2004
yeah thats definately a good point
thats why I mentioned checking the timing both ways first. Most people ignore the truth (including my post) but my teachers repeatedly tell me to address the cause of the problem not the effect.
N
NY Eric
67
Carmel NY
Sep 17, 2004
  • Sep 17, 2004
chiming in
Glad you didnt think I am steping on your toes. At forced4 we have had a run on headgaskets lately. It seems it is now fun to unhook the knock sensor and run the car till she blows.
I just thought I would mention the consequences of an accidental detonation.
TurboCoupeWHITT
46
Ashland,Ky
Sep 17, 2004
  • Sep 17, 2004
ok i toolk my car to my freinds house who is a mech... and had a timing gun and knows what he is doin ....he said my car was in time and he said he thinks the knock sensor is ****ed up and told me if i unplugged it i should be fine......then it started raining and i was goin to run more boost but the rain messed that up cause everyone know TC are bad on wet streets...so until then is there anything i should check
Stinger
7,754
24
118
Basehor (Kansas City), KS
Sep 17, 2004
  • Sep 17, 2004
The knock sensor won't cause that...
Sounds like a boost leak between turbo and throttle body, your vam hose is sucking shut, or your fuel pressure regulator is bad...
351wcoupe
1,811
Manhattan, Kansas
Sep 18, 2004
  • Sep 18, 2004
351wcoupe said:
My opinion......
I agree...
TurboCoupeWHITT
46
Ashland,Ky
Sep 18, 2004
#10
  • Sep 18, 2004
  • #10
Hmmm i had my hopes up tha it was that.........but now i guess its back to checking my intercooler hoses, buy a new fuel press. reg. , and about the vam hose how would u check that ...
Stinger
7,754
24
118
Sep 18, 2004
#11
  • Sep 18, 2004
  • #11
Don't buy a fuel pressure regulator...just check your fuel pressure...it's WAY cheaper
Make sure the vam hose has a coiled wire inside of it that holds the hose open...
You can also grab the hose and see if there is tension when you try to squeeze it shut or if it's really flimzy.
M
mightypoof
523
Glendale, AZ
Sep 19, 2004
#12
  • Sep 19, 2004
  • #12
If your going to buy a FPR then get an adjustable one for a few bucks more, you'll be happy in the long run...Especially If your turning the boost up.
TurboCoupeWHITT
46
Ashland,Ky
Sep 19, 2004
#13
  • Sep 19, 2004
  • #13
ok my vam hose is holding up strong ive checked my intercooler connections ......so i guesss next is to check my fuel pressure ... more than likley purchase pressure reg... anyone have any suggestions on what brand to buy that reliable ... and what psi should my fuel be pushing
Stinger
7,754
24
118
Sep 19, 2004
#14
  • Sep 19, 2004
  • #14
Get a Kirban unit for an 87-95 5.0 Mustang...should only be about 65 bux if you shop for them.
It should be ~38psi at idle with the vacuum line removed from the top of the regulator.
A
a351Must2
Windsor II
4,317
Snohomish, WA
Sep 19, 2004
#15
  • Sep 19, 2004
  • #15
Did you ever answer if you used Motorcraft parts for your tuneup? It's unbelievable how picky these engines are about the spark plugs, wires, and coil used. The only spark plugs I'd trust are Motorcraft or NGK...anything else and you're likely not even sparking above 10psi of boost.
Ask your buddy with the DSM what happens if he uses anything other than NGK... I used Bosch in my DSM once and took it to the dealer because I couldn't get more than 3psi before the engine started bucking/missing.
TurboCoupeWHITT
46
Ashland,Ky
Sep 20, 2004
#16
  • Sep 20, 2004
  • #16
Yeah Motorcraft all the way..... ill ask my friend with the DSM.....or ill tell him more liek it cause we are tearing his motor apart puttin new pistons in it and he is boring it 20 over and putting pretty much everything in it new and swaping a 16G for his turbo and a Front mount intercooler ill be sure to tell him to get NGK plugs...thanks for the advice.. im getting ready to get a 91 Talon my self cause ive road in my other friends Evo 8 and the awd has got my by the heart .... i love the power and traction awd gives u...
TurboCoupeWHITT
46
Ashland,Ky
Sep 25, 2004
#17
  • Sep 25, 2004
  • #17
ok the problem was a simple plug after all i went and changed the crappy plugs and put some NGK in it and it boosts whatever iw ant it 2... im runnin 18 psi right now i love it all though im goin to crank it down to around 17 psi thanks for the help every one
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
