  • 1994 - 1995 Specific Tech
Boost ret ???'s
  • Thread starter Thread starter dstanggt50
  • Start date Start date Nov 18, 2005
dstanggt50
1,316
Woodinville, WA
Nov 18, 2005
  • Nov 18, 2005
My s-trim came w/a msd box w/the boost ret, and I already have a crane hi-6 system on my car. I don't really like msd (had some friends that ran into problems) and was wanting to use my crane, I thought all that was necessarry was an additional part (I think the timing retard control) but summit said I need the TRC and a map sensor. I haven't even started on the ignition install yet (just got done punching the whole and getting the t-rex hooked up), but does the msd come w/both a TRC and a map sensor???, and also are both required if I want to use the HI-6?? The reason why I'm asking is because they want to charge 118.00 for the TRC and another 50 for the map sensor, if thats the case, I may just use the msd that came w/the kit,
Thanks,
dstanggt50
1,316
Woodinville, WA
Nov 19, 2005
  • Nov 19, 2005
ttt
4Jenna
4,326
AZ
Nov 19, 2005
  • Nov 19, 2005
So they are saying you need those with the S-trim, or with that ignition?
I ran a S-trim and a BTM for years..you dont need that **** they told u...map sensor is GM.
dstanggt50
1,316
Woodinville, WA
Nov 19, 2005
  • Nov 19, 2005
Yeah, there saying that if I want a boost ret capability w/my crane hi-6, I would need the timing ret control (trc), and the map sensor to get it to work. I briefly looked at the msd setup sent w/the s-trim kit, and I didn't really see a map sensor?? I saw a knob w/a degree amt to ret the timing, (I'm assuming that was the msd trc). If I have to spend 160 just to get my crane working, may look into using the msd that came w/it.
So all I need is the trc and not the map sensor??? ,
4Jenna
4,326
AZ
Nov 19, 2005
  • Nov 19, 2005
The msd kit will work as is, but what you should do is ditch that and get a custum chip burned.
For now hook the msd btm up for safety, everything you need comes with the kit.
Chris
4Jenna
4,326
AZ
Nov 19, 2005
  • Nov 19, 2005
I tried hitting you on yahoo im
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 19, 2005
  • Nov 19, 2005
i got one here for ya, i had the crane kit on my 95 cobra, it was the kit from summit that comes with the coil and the box and the plug in connectors and ****, anyway i got the vortech kit and didn't use the msd btm box,my tuner said when he reflashes the chip for the blower they will set up all the timing tables and i wont need the msd btm kit,the crane box would be fine. so i get the car there and on the dyno they told me the igniton was breaking up and they ended jury rigging an msd 6al in to see if it cleared up, which it did, so the msd 6al has been in my car ever since. the msd btm from the vortech kit i ended up selling for $250 to some guy in down in the islands, i forget which one, but some tropical place.
dstanggt50
1,316
Woodinville, WA
Nov 19, 2005
  • Nov 19, 2005
I am going to either get a tune or try messing around w/a tweecer, but I spent all of my money on the s-trim, so I don't really have the money right now.
eades: I don't really use the IM, because of work, but if you had any add info, please email me dstanggt50@yahoo.com
95cobra: So you just got it tuned and used a standard ign box w/out the the boost ret hooked up??
9
95cobradude
Banned
Apr 1, 2005
194
long island, ny
Nov 19, 2005
  • Nov 19, 2005
pretty much, chip burned for timing and regular msd 6al for ignition,
4Jenna
4,326
AZ
Nov 19, 2005
#10
  • Nov 19, 2005
  • #10
yup
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
