Boring a 5.0 +.060
  • Thread starter Thread starter 50FoxBodyGT
  • Start date Start date Aug 28, 2006
50FoxBodyGT
74
Memphis
Aug 28, 2006
  • Aug 28, 2006
Hey guys,
How do feel about boring a 5.0 to +.060? Has anyone had any good/bad experiences doing this? Is it just too much or will I be okay?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Aug 28, 2006
  • Aug 28, 2006
I'm pretty sure you'd really be pushing it on a factory block. The figure I've always heard for a stock block is .030 over, .040 being the absolute max before needing to have it sleeved or having to pick up a new block.
85ragtop
BTW, I like dudes.
475
123
NC
Aug 28, 2006
  • Aug 28, 2006
I don't know about the 302. My 351 is .060 over. No probs so far.
50FoxBodyGT
74
Memphis
Aug 28, 2006
  • Aug 28, 2006
I think the 351 might have thicker walls, though. Not sure on that. What's the issue with over-boring? Is it that the engine will run hot or am I going to bust a rod or something through the cylinder wall?
R
R2D2
Aug 28, 2006
  • Aug 28, 2006
If your chosen machinist doesnt have the ability to sonic check the block and tell you the numbers then run away. Some will take, most wont. Unless your .040 now there is no advantage to taking it from 4.0-4.030 bore to 4.060. Yes the issue is the thrust side of the cylinder.
Woodrow
183
Atlanta/Auburn
Aug 28, 2006
  • Aug 28, 2006
I have a .070 motor that I run with no issues. I wouldnt advise it on the street though.
Shakin66
628
Waycross, Ga / Lake James, NC
Aug 28, 2006
  • Aug 28, 2006
I have bored two 302's to 60o/s and both ran hot....I swore i'd never do it again the second time.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Aug 28, 2006
  • Aug 28, 2006
Exactly, 308 is the biggest I'd go on a stock 302.
dastang2
2,020
tx
Aug 28, 2006
  • Aug 28, 2006
i have done it with no problems. yes it runs hotter at around 260-290 on a stock 3 core truck radiator but an aluminum radiator and electric fan would help a lot. i still have the pistons from it since the bearings didn't last.(because i didn't get the block allign honed
P
Phatt_daddy
219
Hytop, AL
Aug 28, 2006
#10
  • Aug 28, 2006
  • #10
the stock engine in my '87 was .060 and I had no problems w/ electric fan and stock rad.....until I killed the compression rings. Finally got around to puling the pistons out and 6 out of 8 the top ring fell off into 4 pieces
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
