First, in case you forgot, or you didn't read it, here's the thread explaining my new plan for Sadie:
http://forums.stangnet.com/showthread.php?t=577371
Basically, I had come to the realization that I simply didn't have the skill, money or equipment to be able to properly fix all of Sadie's rust issues so I decided to pull what was good off of her and wait until I got out west (to that mythical land of rust free cars
) to find another mustang to put her good parts on.
Well, I happened to get a fair amount of money (no, I didn't rob a bank
) so I started looking locally. Most of what I found were either too far away, way out of my price range, or junk. Then I happened to find an ad in an autotrader (actually, I didn't see it the first time I looked through the mag. I was about to throw it out a few days later and decided to give it a quick glance through again and that's when I saw the ad).
http://chelle.mine.nu/hostingpics/mustangad2.jpg
It sounded interesting so I called and made an appointment to see it.
Went up there Friday, looked it over really well (crawled all over the ground with a flashlight & stuck my head in all the nooks & crannies) and for the most part, it was a VERY solid car. The only rust I found was a little on the driver's side cowl, the battery apron, bottom corner of the outer wheel housing on the driver's side, a few small bubbles here & there, 2 spots on the hood that had been sort of patched with bondo, and the bottom of the radiator support. That's all. Floor pans, torque boxes, frame rails, trunk floors, toe boards, fenders, quarters, headlight buckets, etc, all appeared to be rust free.
We were going to test drive it that day, but only one of the brake lights was working so the mechanic (very nice guy, btw) said he'd fix it and we could come back in a couple days to drive it. It ended up only taking a day to fix it (bad ground) so we went back yesterday and I drove it around a little and it ran pretty good so I made an offer, he countered, and now I have another mustang.
The plan is to use it as a daily driver (I needed a car anyway and this is a heck of a lot better than a POS Honda) while I rebuild Sadie's engine. I'll also transfer a few things from Sadie to it (like her console, recovered seats, hood etc) and use some of the new parts I'd bought for Sadie on it (like the battery apron & outer wheel housing). So it will be like Sadie's getting the body transplant that she needed, but with less blood, sweat, tears, swear words, & money than if I'd actually replaced all the rusted stuff on her.
And since I know someone's going to pull this if I don't post pics . . .
. . . here's some pics.
Exterior:
http://chelle.mine.nu/sadie2/outside01.jpg
http://chelle.mine.nu/sadie2/outside02.jpg
http://chelle.mine.nu/sadie2/outside03.jpg
http://chelle.mine.nu/sadie2/outside04.jpg
Interior:
http://chelle.mine.nu/sadie2/inside02.jpg
http://chelle.mine.nu/sadie2/inside03.jpg
http://chelle.mine.nu/sadie2/inside01.jpg
Trunk:
http://chelle.mine.nu/sadie2/trunk01.jpg
Engine (yes, the power steering works):
http://chelle.mine.nu/sadie2/engine01.jpg
The bad stuff (rust):
Outer wheel housing
http://chelle.mine.nu/sadie2/rust02.jpg
Viewed from inside the trunk
http://chelle.mine.nu/sadie2/rust01.jpg
Battery apron from the underside
http://chelle.mine.nu/sadie2/rust03.jpg
Spots on the hood (Sadie's hood is actually in better shape so I'll most likely use it)
http://chelle.mine.nu/sadie2/rust04.jpg
http://chelle.mine.nu/sadie2/rust05.jpg
Radiator support
http://chelle.mine.nu/sadie2/rust06.jpg
Driver's side cowl
http://chelle.mine.nu/sadie2/rust07.jpg
Passenger's side cowl looks pretty good. I think the collar was replaced (never actually seen an intact original cowl collar so I can't tell for sure), but it appears to be nice & solid.
http://chelle.mine.nu/sadie2/cowl01.jpg
Tomorrow I'm taking it to get inspected & registered so I'll take my camera and snap some shots of the undercarriage while it's up on the lift.
-Chelle
) to find another mustang to put her good parts on.Well, I happened to get a fair amount of money (no, I didn't rob a bank
) so I started looking locally. Most of what I found were either too far away, way out of my price range, or junk. Then I happened to find an ad in an autotrader (actually, I didn't see it the first time I looked through the mag. I was about to throw it out a few days later and decided to give it a quick glance through again and that's when I saw the ad).http://chelle.mine.nu/hostingpics/mustangad2.jpg
Exterior:
Interior:
Trunk:
Outer wheel housing
Radiator support
Driver's side cowl
-Chelle
