I just bought a used Vortech V2-SQ kit which includes the head unit, oil lines, bypass valve & tubing, discharge tube, inlet tube, air filter, FRPP 42 lb injectors, mass air meter.
This is the shopping list I've put together so far. Please feel free to help out and add what you think I will need. I'm planning on running the stock 8-9 # pulley for now.
Bracket & parts: 4FL111-031, MTNG BRKT ASSY 00-04 2V GT
Focus fuel pump: 3S4Z-9H307-BC
Right now, the car is stock except for magnaflows & O/R X-pipe. Hopefully I can find a good tuner here in Houston that uses SCT.
Vortech charges $294.95 for the above bracket kit, which includes main bracket, idler assy, radiator tube, all bolts & parts. Is there anywhere cheaper to get it?
Whatever advice you can offer is appreciated.
I'm stoked!
:SNSign:
I'm stoked!
:SNSign:
