  • 1994 - 1995 Specific Tech
BOV question
  • Thread starter Thread starter 5.0DuDe
  • Start date Start date Dec 10, 2005
1 of 2 Next Last
5.0DuDe
59
  • Dec 10, 2005
okay so heres the deal i have a 94 gt with a vortech v1 and i wanted to know if i would be able to run a HKS super sequential BOV without recirculating it i have seen a couple cars doing this and wanted know what was nessesary to run the blow off to the atmosphere i got the blow off valve for my birthday and would really like to use it
OrangeMustangGt
1,976
Cape Cod, MA
Dec 10, 2005
  • Dec 10, 2005
Do you really need a BOV with a supercharger running low psi?
4Jenna
4,326
AZ
Dec 10, 2005
  • Dec 10, 2005
Yes he needs it.
You have to use it like a bypass valve if you blow it off the car WILL NOT be running correctly as you are letting metered air out.
Since the Vortech cars put the meter BEFORE the bypass you have to recirculate it..any setup (procharger/turbo) with the meter after the valve it is fine to vent it wether its supercharged/turbo'd
Chris
5.0DuDe
59
  • Dec 10, 2005
okay so i have figured out how to recirculate the blow off valve back to the motor so since i have a power pipe on the car also would this mean me having to run a long tube down to inside the fender wall before the mass air right
a50sn95
368
Elk Grove, CA
Dec 11, 2005
  • Dec 11, 2005
No, the air has already gone through the MAF. It needs to re-enter after the MAF, but before the supercharger. If you do it before the MAF you'll be measuring it again....
4Jenna
4,326
AZ
Dec 11, 2005
  • Dec 11, 2005
Yup
5.0DuDe
59
  • Dec 11, 2005
okay i got it so im going to buy the recirculation flage for the blow off and then run a hose to the power pipe would i have to do anything else to make this work
4Jenna
4,326
AZ
Dec 13, 2005
  • Dec 13, 2005
U dont have to have the re-circle flange..my hose fits over my Greddy..but it will make it a lil easier
I go for budget though..hehe
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Dec 13, 2005
  • Dec 13, 2005
Have pictures of the BOV you plan on using? The one I have is impossible to recirculate, but im gonna try it anyways.
4Jenna
4,326
AZ
Dec 13, 2005
#10
  • Dec 13, 2005
  • #10
Greddy Type-S
http://www.suprasport.nl/images/Greddy_typeS.jpg
YEAHLOH95
1,249
EVERETT,PA
Dec 14, 2005
#11
  • Dec 14, 2005
  • #11
i want one of them cause i like the noise it makes :Word: ,i'm going to try venting first then reciclulating if need be
BlueOvalStangGT
2,849
Dec 14, 2005
#12
  • Dec 14, 2005
  • #12
Eades, can you still hear it even if its recirculating?
4Jenna
4,326
AZ
Dec 14, 2005
#13
  • Dec 14, 2005
  • #13
It doesnt sound like u think..lil louder than a Bosch
Also I def wouldnt rec trying to vent it...thats a VERY bad idea
E
ef200098
123
#14
  • Dec 14, 2005
  • #14
BOV will work on turbo but not supercharged cars.
4Jenna
4,326
AZ
Dec 14, 2005
#15
  • Dec 14, 2005
  • #15
And to think..some people would prob take this advice..haha
You couldnt be more wrong.
Call Vortech..call Greddy..then come back and edit your post again.
4Jenna
4,326
AZ
Dec 14, 2005
#16
  • Dec 14, 2005
  • #16
To clarify..
If the air is re-circulated..a BOV will work just like a Bypass valve
BOV/Bypass either will work
BlueOvalStangGT
2,849
Dec 14, 2005
#17
  • Dec 14, 2005
  • #17
Yeah seriously, its the same exact thing....just depends if you recirculate or not.
Black95GTS
1,644
Marlborough, MA
Dec 15, 2005
#18
  • Dec 15, 2005
  • #18
Humm.... what makes you think that? It's my understand that in a forced induction setup, at the point where a bypass / blow-off valve comes into play, they're both essentially doing the same thing.
A bypass valve is a valve between the t/b and the power adder that vents extra pressure built up from the compression of the air. If the valve vents the extra pressure to the atmosphere, it is called a blow off valve. If the extra pressure is vented back into the inlet of the power adder, it is called a bypass valve.
Adam
a50sn95
368
Elk Grove, CA
Dec 15, 2005
#19
  • Dec 15, 2005
  • #19
Adam
And really the only reason to use it as a BYPASS instead of a BLOW-OFF is if all this happens AFTER the MAF. If the MAF is AFTER the BYPASS/BLOWOFF, it can vent to the atmosphere...
YEAHLOH95
1,249
EVERETT,PA
Dec 15, 2005
#20
  • Dec 15, 2005
  • #20
what happens if you vent it after, is the car goes rich for alittle bit. i have seen it work on cars before and think its worth at least a try can't hurt right ????
1 of 2 Next Last
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Vortech V3 Si - Bypass Valve to BOV swap issues
  • seanmahoney
  • Jun 26, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 26, 2025
seanmahoney
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
