Boxed Upper Control Arms
  • Thread starter Thread starter Mavrick
  • Start date Start date Jul 27, 2004
Mavrick
2,264
Collingwood, ON
Jul 27, 2004
  • Jul 27, 2004
I've seen these for sale.. stock control arms that have been boxed in. How does this help improve the stock control arms and does it work?
When i swap my diff, im putting in new springs and my buddy could weld up my control arms.. is it worth it?
Thanks.
V
v8only
2,378
22
49
Jul 27, 2004
  • Jul 27, 2004
imo, it's a very cheap backyard fix to lousy control arms. Picture the uppers, they are u shaped. Welding the plate on top keeps them from flexing. However, this doesn't address the fact that they are still using old bushings. IMO it's not worth it. Get a good frpp or 93 cobra upper set and be done with it. they only cost $50 or so.
Mavrick
2,264
Collingwood, ON
Jul 27, 2004
  • Jul 27, 2004
I'm swapping diffs.. with new bushings.. and welding them is FREE as apposed to $150 control arms, or $250 (im in canada eh, everything is more expensive).
I was just wondering how well i would benefit from welding the uppers.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 27, 2004
  • Jul 27, 2004
The stock controll arms are just stamped steel. The steel is thick enough, but the shape is very weak. Like said before, turning the U into a D so to speak greatly strengthens them. The bushings are crap though. If you can get them welded free, or real cheap, go for it. Do the lower's too and then get the poly rear bushing set for under $40. This will make a huge difference because the stock bushings you can twist the whole arm by hand. It may not be as good as aftermarket, but for the budget minded and/or just street mustang it won't make much difference.
Mavrick
2,264
Collingwood, ON
Jul 27, 2004
  • Jul 27, 2004
Hmm, welding the lowers would mean that i would lose my sway bar?
TIMMY2734
1,330
Queens, NY
Jul 27, 2004
  • Jul 27, 2004
Weld them up. The price sounds great and its a win win situation. The worst that wil possibly happen is they feel the same...as stock. But no money lost, no harm done.
For anyone who knows Kevin Slaby of baseline suspensions, he cut consistent 1.6 60s with stock boxed arms ....
TrophyHead
1,195
11
49
PA
Jul 27, 2004
  • Jul 27, 2004
I think Hallon4wheels did this.
I'm subscribing.
TIMMY2734
1,330
Queens, NY
Jul 27, 2004
  • Jul 27, 2004
You could probably weld a nut the the control arm or figure something out to make it work.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 27, 2004
  • Jul 27, 2004
It's important to note, those arms (I didn't know they were on the 93 Cobras) are just stock arms with stiffer bushings. They would still be u-shaped and not boxed.
90mustangGT
2,773
17
89
Dallas, GA
Jul 27, 2004
#10
  • Jul 27, 2004
  • #10
Good point.
The swaybar could still be mounted as long as you didn't box it too far to get the bar and a wrench in there.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
R
Rear Upper Control Arm Pivot Point
  • Rcdgl
  • May 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2025
Rcdgl
R
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
