brake booster question
  • Thread starter Thread starter lmpbzkt492
  • Start date Start date Oct 27, 2006
L
lmpbzkt492
68
  • Oct 27, 2006
today i found a hissing noise coming from around the brake booster area and after some listening have concluded it is coming from the brake booster. if i pinch off the hose going to the booster the hissing goes away. does this mean my booster is bad or is it just the valve that comes off the booster that the hose connects to? Thanks
L
lmpbzkt492
68
  • Oct 27, 2006
any ideas??
7-UP BILL
885
My other car is a Firetruck
Oct 27, 2006
  • Oct 27, 2006
Does your pedal feel any different? If it starts getting hard, it's most likely losing vacuum. If you pinch the line going to it and the hissing stops, the diaphram inside the booster is probably shot. What year is car? I have a booster in great shape if your interested. It's from a '90 and had 15k on it when I removed it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 28, 2006
  • Oct 28, 2006
A small rubber hose used as a stethoscope to listen & locate the leak may be helpful. The rubber grommet that the brake booster mounts the vacuum check valve in is a known source of leaks. Use the rubber hose trick to see if the leak is in that area. If it is, the grommet is cheap, only $2-$3 to replace it.
L
lmpbzkt492
68
  • Oct 28, 2006
i guess i could start with the check valve first being that it is the cheapest. would any auto parts store carry that part? the thing that im the most mad about is that i just had the booster replaced a little over a year ago. but if i pinch the line and the hissing goes away im guessing it is most likely the booster and not the valve
old_blue
1,783
282
124
Oct 28, 2006
  • Oct 28, 2006
have you checked the hose for cracks?? that would be my first area as those are hardly ever replaced and are usually the culprit. you may be pinching it off right before the crack is.
RYC CUKR
1,437
Orlando
Oct 28, 2006
  • Oct 28, 2006
Get a can of TB cleaner and lightly spray it around the booster, hoses and anywhere else you suspect the leak may be. If the engine idle increases when you spray a certain area that is where you leak is. This is how I check for leaks after doing an intake swap.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 29, 2006
  • Oct 29, 2006
I would check the Vacuum Tree and the Hose to the Booster
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
