Brake Caliper Torque Specs?
A torque is measured in ft.lbs, not psi (psi is pressure)
To answer your question, the bolts that hold the caliper to the bracket should be torqued to 85 ft.lb.
Post a pic of you calipers. I painted mine performacne red to match the car.
85ft-lbs???
85? that seems awfully high. The wheel bolts get 95 and they are twice the size. May i ask where you got that number? My internet research comes up with 30-35 ft-lbs.
