Brake conversion
  • Thread starter Thread starter Critter_04
  • Start date Start date Sep 3, 2004
C
Critter_04
49
Ohio
Sep 3, 2004
  • Sep 3, 2004
Is a brake conversion kit really worth it, or should I just stick with the drum brakes in the back. I dopnt really like drum beakes, they just look bad but it gfets a littel pricy to do it any input, anybody recomend it or not recomend it?
Rick 91GT
Mustang Master
95
99
PA
Sep 3, 2004
  • Sep 3, 2004
Disc brakes are much better then a drum, they have better clamping force and holding power.
It is necessary? Maybe not the stock drum set-up works well for most set-ups.
What are your intentions with the car?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 3, 2004
  • Sep 3, 2004
Do the Turbo Coupe rear end swap and get gears & disk brakes in one package all at the same time...
Auto trans Turbo Coupes come with 3.73 gears and manual Turbo Coupes come with 3.55 gears. I choose 3.55 since I do more highway driving. Both ratios have 10.5 disk brakes with vented rotors as standard equipment.
It takes 2 guys the first day to get the old rear end out and the new one bolted in place. It takes 1 guy another whole day to do the brakes.
You will need a several sets of fittings, I recommend that you get them from Matt90GT's website, http://www.svo73mm.cjb.net/. Read Matt's instructions thoroughly, everything you need to know about the brakes is all there. You need to be patient and follow all the internal links, and there are many of them. You will need 2 fittings in the rear to adapt your old brake tubing to the TC disk brakes. The fittings go between the steel tube and the caliper brake hose. You will need another set of fittings to make a 2 port to 3 port adapter. To make life simpler, just buy the kits from Matt. You could piece them together, but it's not worth the time unless you work at an auto parts store with all the fittings ever made.
You will need to drill the quad shock mounting holes 2” below the holes drilled for the Turbo Coupe mounting points. The bolts are metric, so don’t loose them or the nuts. A 15/32” drill should be about the right size unless you have access to metric sized drill bits. Going without quad shocks is not an option unless you have aftermarket parts to soak up the wheel hop.
You will need a proportioning valve, Summit has one for $40 + shipping.
You will need a kit (FMS makes the part) to gut the stock proportioning valve, Summit also has that, about $10.
You will need a new master cylinder, see Matt's site and make you choice. I used a 94-95 Mustang master cylinder. Note that rebuilt 94-95 Mustang master cylinders do not come with a reservoir. That means a trip to the junkyard and some more money spent.
Your brake pedal may be very hard and almost impossible to lock up the brakes. I had to replace the front calipers with 73 mm calipers from a 91 Lincoln Mark 8 to get the braking performance up to par.
Bleeding the brakes will require 2 people and some coordinated effort. I don’t recommend using you wife or girlfriend to pump the pedal – they get offended when you yell at them. I used a homemade power brake bleeder constructed from a garden sprayer and some fittings from Home Depot. It cost about $25 and was worth every penny.
See http://www.mustangcentral.net/tech/brake.html for help with the emergency brake - the stock setup tends to lock up and not release properly.
All in all I have been very pleased with the results.
C
Critter_04
49
Ohio
Sep 3, 2004
  • Sep 3, 2004
Thanks for the help jrichker
Sevan
558
IL
Sep 3, 2004
  • Sep 3, 2004
I second the Turbo Coupe swap, just did mine recently.\
xplo89gt
945
Boston, MA
Sep 3, 2004
  • Sep 3, 2004
how much does the 94/95 mc cost if you go the rebuilt/junkyard route? I was going to order off of Maximum Motorsports. It is $99 + $35 for adapter.
F
fost9508
131
  • Sep 3, 2004
sevan,
off topic.....
you have to tell me where you found that avatar...I need to go locate that picture.......is real size....its awesome!
Sevan
558
IL
Sep 3, 2004
  • Sep 3, 2004
fost9508, what are your plans with my avatar? i have the pick ready but it have to give a good reason for the full pic....
Sevan
558
IL
Sep 3, 2004
  • Sep 3, 2004
heres the full pic of my avatar
http://forums.stangnet.com/attachment.php?attachmentid=27583
F
fost9508
131
#10
  • Sep 5, 2004
  • #10
to be honest I didn't realize it was a personal pic...thought you grabbed it off some website....props though.
Sevan
558
IL
Sep 5, 2004
#11
  • Sep 5, 2004
  • #11
Dont worry about it, its cool
Rick 91GT
Mustang Master
95
99
PA
Sep 5, 2004
#12
  • Sep 5, 2004
  • #12
Don't forget the Turbo rear swap puts the rear tires out an additional 3/4" per side...
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
