  • SN95 4.6L Mustang Tech
Brake conversion
  • Thread starter Thread starter doubleomustang
  • Start date Start date Jan 2, 2007
1 of 2 Next Last
doubleomustang
73
Spartanburg SC
Jan 2, 2007
  • Jan 2, 2007
i was wondering if anyone knows about using rotors and calipers off of a different car on a 2000 GT. Im dirt poor and need a better brake system. eventually i might get something better. so if any one has any ideas about calipers from an expedition or
f150. i just need calipers that will fit a larger rotor. i have a problem with my rotors warping so i thought that larger discs would help improve that and stopping distance.
blubullett
535
Modesto, CA
Jan 2, 2007
  • Jan 2, 2007
You can get bullitt or cobra brakes from buyfordracing.com for sorta cheep. Or maybe get cobra brakes from some wrecking yard, but the pads are still expensive if they dont come with good ones. Mustang parts specialties might not have them for a bad price either, but i dont remember their web address.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 2, 2007
  • Jan 2, 2007
buyfordracing.com is the best place ive found for the cobra/bullitt/mach-1 13" upgrade
for about 330-340 shipped you can get the mach kit that comes with all new parts
calipers
pads
brembo rotors
stainless lines (includes banjo bolts and crush washers)
doubleomustang
73
Spartanburg SC
Jan 2, 2007
  • Jan 2, 2007
thats alot better than i have found them for...are these still only double piston calipers tho...will they be an improvement over stock?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 3, 2007
  • Jan 3, 2007
ya they are better than stock. i think the cheapest 4 piston kit you will find is the one that i have. also your wheels wont work with a 4 piston caliper.
blacksheep-1
322
Jan 3, 2007
  • Jan 3, 2007
You could scrounge around and find some (relatively) cheap cross drilled rotors and use Hawk pads. I run NASA and am not allowed to change the brakes so that's what I did. It's an improvement. Try summit for the rotors and check out a hard core race store for the pads. BTW expect them to squeak.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,114
224
Massachusetts
Jan 3, 2007
  • Jan 3, 2007
YES x10
The major difference is the 13" rotor vs the 10.8" GT rotor
Leverage is your friend
doubleomustang
73
Spartanburg SC
Jan 24, 2007
  • Jan 24, 2007
so these mach 1 and cobra calipers are triple piston calipers?
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,114
224
Massachusetts
Jan 24, 2007
  • Jan 24, 2007
2-piston
N8Dogg98
3,872
238
184
MN
Jan 24, 2007
#10
  • Jan 24, 2007
  • #10
I have Hawk pads, and Power Slot slotted discs all the way around. It made a huge difference over stock. They grab hard, and unless you take your car to the track should last you a long time. Also, you won't have to worry about your stock wheels fitting around them.
doubleomustang
73
Spartanburg SC
Jan 24, 2007
#11
  • Jan 24, 2007
  • #11
so i need 13" rotors that are slotted with cobra or mach calipers. are the calipers going to be much different since they are still double pistons. should i go with slotted or cross drilled rotors?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 24, 2007
#12
  • Jan 24, 2007
  • #12
you dont need slotted or crossdrilled rotors. if you want the look then ya get them. if you plan on autocrossing or open tracking your car, dont get them.
calipers "look" similar to the 99-04 V6/GT pistons but are different. i just ordered new rotors and pads for my setup. i got Brembo blanks rotors(NOT slotted or crossdrilled) and Hawk HPS pads.
doubleomustang
73
Spartanburg SC
Jan 24, 2007
#13
  • Jan 24, 2007
  • #13
are the cross drilled or slotted not spose to have an advantage over the plain rotors? how are the cobra calipers different from the stock GT?
forum155pl
520
the 509
Jan 24, 2007
#14
  • Jan 24, 2007
  • #14
yeah they are supposed to be better.. for normal street use, but if you are hard on them like with autocrossing then they warp really easy...
cobra calipers are dual piston as the GT's are single... but the cobras also use a bigger rotor then the GT does so you have more leverage over a smaller rotor...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 24, 2007
#15
  • Jan 24, 2007
  • #15
partly true. the 94-98 GTs had a single piston, however the 99-04 had a dual piston caliper on the same size rotor. they are all made by PBR IIRC, but the Cobra PBRs are a different design. PBR is an Australian company that also makes the OEM brakes for Corvette, Monaro/GTO, as well as the Baer kits.
forum155pl
520
the 509
Jan 25, 2007
#16
  • Jan 25, 2007
  • #16
99-04 had twin!!!!! i hate you guys...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 25, 2007
#17
  • Jan 25, 2007
  • #17
well i have 4 piston front calipers. although if i did it all over i wouldve gone with the 6 piston front and 4 piston rears with integral drum parking brake on the rear.
whats nice about the Cobra R front setup is that it uses the same brake pads as a Dodge Viper. its actually easier on parts people if you tell them you have a viper than a cobra R. although tirerack has a seperate listing for cobra R's.
forum155pl
520
the 509
Jan 25, 2007
#18
  • Jan 25, 2007
  • #18
I'm just going to put a parachute on my car.... lol
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 25, 2007
#19
  • Jan 25, 2007
  • #19
You say you're dirt poor? Then why do you think you need better brakes? The '99-up cars with their PBR dual piston front calipers and rear disks set ups are more than capable of halting a Mustang with stock size wheels down from any speed.
urban96
3,464
Syracuse, NY
Jan 25, 2007
#20
  • Jan 25, 2007
  • #20
does the viper use the same caliper with the same mounting bracket as the 00r? i know the focus brembo's are the same as the cobras
1 of 2 Next Last
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
A
Help Needed! 2012 S197 brake caliper dimensions
  • AussieDavid
  • Mar 28, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 28, 2026
AussieDavid
A
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
