F fordtech28 Member May 12, 2006 312 0 17 Riverside Cali. Apr 21, 2007 #1 Apr 21, 2007 #1 What is the best way to flush ALL the brake fluid from a car .I need to do it to my cobra because its pretty dark and I tried it before but I still didnt get all of it out it was still a little dark.Any ideas how to do it right?
Bosko5.0 Active Member May 18, 2006 1,067 0 37 longwood, FL Apr 21, 2007 #2 Apr 21, 2007 #2 I flushed myne by bleeding the front brakes and kept refilling the resevoir, when the front looks clean do the rears until they are clean.
trav_19 New Member Oct 29, 2006 810 0 0 Jackson, MI Apr 21, 2007 #3 Apr 21, 2007 #3 bleeding the lines are the only way i know how to do it too
E ernest russell New Member Apr 5, 2007 5 0 2 Apr 21, 2007 #4 Apr 21, 2007 #4 i use a air operated vaccum pump it also has a bottle that keeps your master cyl.from getting empty,you put the tube on your bleeder than open it .
Gibbo97 Founding Member Apr 20, 2001 92 0 7 Macon, GA Apr 21, 2007 #5 Apr 21, 2007 #5 http://www.motiveproducts.com/02bleeders.html I used that to bleed my brakes- took about 10 mins after getting the wheels/tires off.
