Brake Guru's - '86 Notch
A friend called me and has an '86 4cyl coupe that had a V8 conversion done by a previous owner.
His front brakes are giving him trouble and I have some good V8 rotors, calipers and pads off a '90 sitting in my garage.
Will the V8 parts bolt right up to the 4cyl spindles without any modifications, or are the spindles and mounting points for the calipers completely different?
Any help is appreciated. :hail2:
You will need 87-93 spindles,backing plates and struts to use your 1990 parts on the 86 as far as I know.
(I`m not 100% positive on the 87-93 struts but most guys use them,but I vaguely recall reading about spacers years ago that would allow you to keep the 86` struts:shrug:).
He would be better off with new 87-93 struts anyways.I`d go with 87-93 struts.
