Brake Hoses....
  • Thread starter Thread starter cobraii351
  • Start date Start date Apr 11, 2005
C
cobraii351
1,104
Altoona, PA
Apr 11, 2005
  • Apr 11, 2005
Anyone who has done the Granada brake swap what did you do for hoses? I found hoses that work but they are not quite long enough. Doing some work this weekend and I found a couple of spots that had become chaffed. I was looking to possibly get braided lines, but was unsure about this. I don't know the application of the hoses I have now and I want a D.O.T approved hose. Anyone have any suggestions?
Thanks,
Tim
D
dmoody
789
Winston-Salem, NC
Apr 11, 2005
  • Apr 11, 2005
I went with the braided lines on mine. They work great but the first pair I got were way too short. The company (Precision Brakes) shipped me new ones the correct length for free so I feel good about recommending them. If you've changed the brake caliper from stock you should let them know when you order.
d
V
vetwhat
40
  • Apr 11, 2005
dmoody, are you using the GM calipers or the FORD ones ?
I used the GM ones from a mid to late 80's trans-am with hoses. they reach, but use metric fittings. I simply cut off the ends of my factory metal lines (ones on the frame ) and put on a metric fitting. been on there for quite some time now with no problems.
D
dmoody
789
Winston-Salem, NC
Apr 11, 2005
  • Apr 11, 2005
I'm using Wilwood calipers. I didn't have to change the fittings on my brake lines. If you order the braided lines they'll come with the correct fittings for the stock brake line.
d
C
cobraii351
1,104
Altoona, PA
Apr 11, 2005
  • Apr 11, 2005
I talked to a guy at Precision Brakes. 35$ each to go from the ford hard line to the GM Metric caliper 20" long. Not too bad. Yet something else to buy AGAIN. What a $ pit I've got......
C
cobraii351
1,104
Altoona, PA
Apr 13, 2005
  • Apr 13, 2005
dmoody,
Thanks a lot! I talked to a Doug at Precision Brakes. Got two new braded lines coming, 35$ each. Nice as hell to deal with. Got me exactly what I needed. It was funny he asked what suspension I had, and what type caliper and the hard line size and then what type or car it was in. He was shocked to hear it was still in a Mustang II! He was like, "wow I don't get to many calls for those.". Great bunch of people, and so far great service. We'll see when the lines get here.
Thanks again,
Tim
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
