Brake info....input please...
drakesdad
961
Oregon OHIO
The missus' came home tonight and said the brakes were grinding on the GTP.
Her dad put brake pads on the front not too long ago and said "next time turn the rotors"...:nonono: I went to take it for a ride and made it less than 50 feet before turning around and parking it. Went to Autozone and bought new rotors and pads......Driver's side outside pad was fine...inside pad was grooved about 1/3 from bottom. Passenger side outside pad was perfect....inside was all "metal"...no pad left......Now the piston on the driver's side went in fine with the c clamp....passenger side was a little tougher but went in....drove it around tonight and all is fine......
I am thinking maybe rotors were "grooved" or warped too bad to begin with or maybe piston on passenger said froze.....any ideas or experience yourselves...
Thanks guys,
Will
If a piston is sticky or the slide pins (a good bet) wont allow decent floating, it can wear the inside pad pretty fast. A bad pin will keep the caliper from being able to self-center, which causes wear and heat, which causes caliper damage.
Many slide pins have a sacrificial coating - if they seem crappy, if not expensive replace them. Otherwise I use synthetic grease on them.
That's the best I got. If parts arent expensive, it's easy to swap the parts. Good luck with it Will. :nice:
My DD is a 2000 Olds Intrigue(sp) and I just did the same thing with the same issue the pad change before yesterday. I would also say the slide pin. I noticed the last time that the inside pass side pad was wearing BAD with the other side preaty even. I put some lube on the slide and this time when I replaced the pads and rotors the pads were even on both sides.
