I am trying to reinstall my stock brake caliper. It's the rear passenger corner. The problem I am having is the lower line (is that the brake line?) seems to be a bit long. So it wants to push the caliper rearward. I can almost get it lined up to mount with a lot of force, but not quite. I spent a good 20 minutes fighting with it to try to get it back.
The other thing that might help is if I could compress the caliper piston. I have just barely enough slack to get it over the pads. I tried opening the reservoir (the plastic cap), and then put a clamp on the piston. But it would not budge. I did not want to break it, so I stopped before applying much pressure with the clamp. Any suggestions on compressing the piston?
I think the hose combined with the piston are both fighting against me enough that I can't get it back on. Has anyone else run into this? Any thoughts on what to do?
I was doing the EXACT same thing 24 hours ago...
