Brake issue?
  • Thread starter Thread starter RUNINAGT
  • Start date Start date Apr 5, 2012
RUNINAGT
237
CHARLESTON S.C.
Apr 5, 2012
  • Apr 5, 2012
1st Sorry I realized this morning I posted this topic in the wrong section, so I am copying it here, which should be the proper section, it was late when I originally posted it and I guess I did not pay attention. Anyway
Issue!
Guys we just installed new calipers, rotors and pads on the front of my stock set up 93GT. We replaced because it was pulsating and when we took it apart the pass front rotor showed some hot spots on it, so our tech recommended to replace the calipers, I figured what the hell they were original to the car and have 100k on them, so replaced they got.
Now I have an issue that I can't remember if I had before. If you are at a slight roll and jab the brakes the pass front wheel assembly will jolt, enough to where if you walk beside the car you can see it and can feel it in the car. Pulsation is back, just not as bad as it was with the old rotors. This brake job was done 2 weeks ago.
So at 1st we pulled the rotor back off, and put it on the lathe and it was warped, no biggie, machined it and back on the car. Jolt still there and pulse seems like it never really went away. You can feel that it is coming from the pass front. So I have ordered another set of calipers and new front hoses to put on. Our supplier will take the others back.
Now another thought we were discussing today is. Could this be a strut issue? Like maybe a bad strut mount? Allowing the force of the brakes and the motion of the car allowing to it move some??? With the old calipers it did not pull when braking, just pulsated.
Thanks
GT
2000xp8
SN Certified Technician
Aug 8, 2003
8,068
1,655
194
NJ
Apr 5, 2012
  • Apr 5, 2012
Check your ball joints.
Sounds like you are running chain store quality parts for your brakes.
Something that is never good.
RUNINAGT
237
CHARLESTON S.C.
Apr 5, 2012
  • Apr 5, 2012
Rotors are the better Ray Bestos rotors, ordered from CJ and the pads were Wagners and the calipers were A1 cardones?
RUNINAGT
237
CHARLESTON S.C.
Apr 5, 2012
  • Apr 5, 2012
Oh yea the front end parts look good and tight? Still OE but look ok.
2000xp8
Aug 8, 2003
8,068
1,655
194
NJ
Apr 5, 2012
  • Apr 5, 2012
Most parts always look tight.
Jack the car up by the control arm, take a big ass crow bar, perpendicular (like a T) under the tire and lift the tire up, see if anything moves.
Ball joints usually either squeak like hell, or bang around.
As for your replacment parts, i always prefer original ford parts or something a little more high end, like brembo for the rotors. There is a reason while the original stuff lasts so long, it's just higher quality.
RUNINAGT
237
CHARLESTON S.C.
Apr 5, 2012
  • Apr 5, 2012
Did that with the ball joints the other day on the front end rack. If it indeed is in the brakes, then why would it make the wheel itself jump ? That's what is confusing.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
