The brake light in my dash is on most of the time in my 97 GT. It is the same light that illuminates when I pull the parking brake.
The light is on nearly all the time when driving. At first, it mostly came on in cold weather when I used the brakes. Then, it spent more and more time on and now is on pretty much constantly.
The ABS system appears to work correctly. I tested several times in a lock up type situation, and in varying condition (dry and wet) and the anti lock brakes always worked perfectly, pulsing as they should. This leads me to believe a sensor for the parking brake is bad.
So where is the sensor for the parking brake? Is it something that can be adjusted or is my best option replacement?
