Brake Lights stuck on?
  • Thread starter Thread starter 25thmustang
  • Start date Start date Jul 8, 2007
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 8, 2007
  • Jul 8, 2007
Alright took the car out for the first time. The first time out the brake lights were stuck on. It only happened twice, and in between they were fine, but the second time they got stuck I tried pulling the pedal back, and it blew the fuse for some odd reason. I took the brake light switch off the pedal and used the one from my dads 91, replaced the fuse and sure enough all day they were stuck on. I had to either take the fuse out or the battery terminal off to shut them off. Does anyone know what could be causing this?
Also to note I have an SN95 Master Cylinder and booster.
Kumm3
527
33
69
East Hartford, CT
Jul 8, 2007
  • Jul 8, 2007
check the brake switch on the pedal, you micht have it out of alignment or not connected correctly.
SmockDoiley
1,591
San Diego, CA
Jul 8, 2007
  • Jul 8, 2007
So the lights are stuck on but it blows the fuse also? That is strange. If its a ground problem it tends to blow the fuse or bulbs, not stay on. Those switches can be installed wrong and stay on depending on the design, but Id check the wiring.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 8, 2007
  • Jul 8, 2007
Well, when I did my SN95 Brakes and first got it together my Brake Lights were stuck on, I changed switches and even switched to the SN95 Style. I ended up loosening the 4 Nuts that hold the Booster in place and just wiggled it a bit and tightened them back up and have never had the problem since.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 9, 2007
  • Jul 9, 2007
Hmm, interesting. Well the reason the fuse blew was because the switch had shifted and was up against the bracket that holds the steering column in. I did not know this, and pulled the pedal up. This is when I saw sparks and the fuse went. I might try the loosen and tighten thing. I am almost 100% sure the switch is in there right, but the lights wont work right. Right now it is the only thing that keeps me from legally driving it, even though it did go to NH yesterday with the brake lights on.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jul 9, 2007
  • Jul 9, 2007
Well at least its better driving around with the brake lights on than driving around with one blinker on all the time. I hate it when people do that.
Anyway, I agree with the other posts. You might have it on backwards. Just double check and make sure.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 9, 2007
  • Jul 9, 2007
It is definately not backwards, but it could be a little tilted up or down (if that makes sense). I will take a look and fiddle with it today to see if I cant get them working right. Weird things are happening with the car, the dash lights didn't work, then started working. Drivers window would go 90% of the way up, and then stopped. It took 10 or more tries of going down then up before it finally went up. But it seems to go up fine with the car just on accessory?
Any more ideas about the switch can try? I can snap pics too if that helps.
cervinistang
11
Dearborn, Michigan
Jul 9, 2007
  • Jul 9, 2007
Wheres that video with the kid who hooked his horn up to his breaks, then let a friend borrow his car?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 9, 2007
  • Jul 9, 2007
Well the reason I ended up loosening the Nuts on the Booster and shifting it around was because with some minor finger pressure I could lift the brake pedal upward and the brake lights would go out. I figured that the Booster had to be crooked and that was pulling the pushrod down just enough to make the brake lights come on, once I got it seated right it was good to go.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 10, 2007
#10
  • Jul 10, 2007
  • #10
I think I figured it out, this piece goes over the shaft of the booster, and is pinned onto the brake pedal with the booster shaft. The rest of it hangs off towards the passenger compartment. I found out why they were stuck on before, I had zip tied it up to keep it away from the steering column mount, and because only the back side of the booster shaft is flat, having it cocked that much up caused the lights to be on. So yesterday I took the zip tie off, and thought I had it mounted in the right place. Turns out the way I mounted it today did not work, and it kept rotating downward when I pressed the brakes, in turn getting stuck behind the support for the steering column. This casued the brake pedal to not 100% release, and the lights to stay on. There HAS to be a way for this thing to stay where it should without me zip tying it just right? I feel bad just zip tying it up enough to not hit, but at this point, there isnt much for me to do.
By the way I have a week and a couple days to figure this out. Car is going from CT to Myrtle Beach SC for Mustangs Week, and NEEDS to go down there.
Saleen0679
876
24
49
Yakima, WA
Jul 10, 2007
#11
  • Jul 10, 2007
  • #11
There shouldn't be that much slop when the switch is mounted. See post #4.
http://forums.stangnet.com/showthread.php?t=699622
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 10, 2007
#12
  • Jul 10, 2007
  • #12
I have it mounted right (nice to have a few Mustangs to look at) but for some reason it seems to be resting on top of the steering column bracket, and when you press the pedal in after a certain point it rotates behind this bracket and then when you let off the pedal the switch is pinned between the pedal rod assembly and the bracket for the column. I have had two of them in there now, and both seem to have the same problem. I was told with it being an SN booster, theres a chance its a 96+ one and therefore might be different? Anyone know anything about this?
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Jul 10, 2007
#13
  • Jul 10, 2007
  • #13
96+ boosters are hydroboost right? Unless it came out of a V6.
Saleen0679
876
24
49
Yakima, WA
Jul 10, 2007
#14
  • Jul 10, 2007
  • #14
I checked and the 95-96 install instructions are the same. Is the plastic bushing and washer in good shape. Sounds like there isn't enough tension keeping the switch in place. Mine will move slightly up and down if I push on it, but it won't drop on its own.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 10, 2007
#15
  • Jul 10, 2007
  • #15
Hmm, maybe the black bushing is in bad shape?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 11, 2007
#16
  • Jul 11, 2007
  • #16
Yes the Newer Booster are different and will cause interference with the Steering Support. The Arm coming out of the Booster into the Car should be turned down like the Stock Fox, if it is just a Straight Arm then it will cause you problems. I always recommend the 93 Cobra Booster as a best fit for our Cars, if you do have the Curved Arm Booster and play in that bushing then I would say thats possible cause too.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 11, 2007
#17
  • Jul 11, 2007
  • #17
I wonder if there is something I can fab up that will keep the switch from getting stuck behind the bracket for the sterring column? That seems to be the only problem as with it held up by zip ties now it works fine. I guess it will be trial and error time in the next week and a half.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 12, 2007
#18
  • Jul 12, 2007
  • #18
Did you get this issue resolved?
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 12, 2007
#19
  • Jul 12, 2007
  • #19
Not yet, I moved the car into the garage right after work for the guy to come and the radio, and he didn't come out until 8 at night. He told me 4:30 and I moved it in, in anticipation of that (can't to the brake thing in the garage, hate having the door propped against something) and he didnt show until 8. When he left it was too late for me to start ripping it apart. I have to take it through emissions friday so I get to try and get cats on it tonight, but might take a look at it at that time.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
