brake lights wont work
  • Thread starter Thread starter ryan218
  • Start date Start date May 26, 2007
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
May 26, 2007
  • May 26, 2007
when i bought the 88 the brake lights were always on like someone was holding the peddle down...easy fix i thought...replace the brake light switch and be good to go...well its not so good and not ready to go...no the brake lights are off...but when i press the brake peddle down nonthing happens.
...the only way i can get them to work is if i pull the contact away from the switch then they will come on...if i try and press the brake peddle down for them to work and i get nonthing ive checked and the switch is hooked up right.....i dont know what is causing this but it sure is aggravating...any ideas? bad connector?
bobbyd
312
San Antonio/Los Angeles
May 26, 2007
  • May 26, 2007
have you checked the fuse?
ryan218
Dec 28, 2005
columbus ohio
May 26, 2007
  • May 26, 2007
yeah its fine...thats the first then i checked for i did anything...it was fine but i replaced it anyway...
HISSIN50
34
129
May 26, 2007
  • May 26, 2007
If you can make it work manually (with your hand) but not with the pedal, it's still an adjustment issue.
Good luck.
ryan218
Dec 28, 2005
columbus ohio
May 26, 2007
  • May 26, 2007
how do i go about adjusting it hissin?
ryan218
Dec 28, 2005
columbus ohio
May 26, 2007
  • May 26, 2007
HISSIN50
34
129
May 26, 2007
  • May 26, 2007
I've done a few (last one was a GM) so I might have my 'wires' crossed. You normally just push the switch (some screw in and out) until the button is almost touching the pedal arm. Have a friend check - you want the lights to come on pretty quick once you start to step on the pedal. Mine are literally hair triggers.
Saleen0679
876
24
49
Yakima, WA
May 26, 2007
  • May 26, 2007
Don't know of any adjustments. Just have to make sure it is installed correctly.
See post #4
http://forums.stangnet.com/showthread.php?t=699622
ryan218
Dec 28, 2005
columbus ohio
May 26, 2007
  • May 26, 2007
See post #4
its 100% like that and its not working
93 LX
3,081
Norwalk, CA.
May 27, 2007
#10
  • May 27, 2007
  • #10
Do you have hazzards? Does the 3rd brake light work? Did you check the fuse?
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
A
Resolved Brake light switch
  • Alabama
  • Feb 24, 2025
4K
General karthief
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
