brake lights
  • Thread starter Thread starter mrmcmillen
  • Start date Start date Aug 25, 2005
mrmcmillen
43
Carrollton, Texas
Aug 25, 2005
  • Aug 25, 2005
my brake lights won't work....and i'm feelin the need to get the car out of the garage.....help me!
i have replaced the brake light swith....that wasn't it.
i tested the power going into the brake light swith and coming out of the brake light swith.....both have power.
my flashers don't work either. front flashers work....dash flashers work....no rear flashers....
i tested the power at the tail lamp too....no luck!
does any one know what the problem could be?
J
JB66
565
New York
Aug 25, 2005
  • Aug 25, 2005
Could be wiring harness, connector or turn signal or hazard switch.
mrmcmillen
43
Carrollton, Texas
Aug 25, 2005
  • Aug 25, 2005
.....damn
Tim65GT
1,149
West Texas
Aug 25, 2005
  • Aug 25, 2005
It's different than my '65, but see if you can check the connector coming out of the column for brake/signal light power. Orange/blue (Right) and Green/Orange (Left). If none, then it could be the hazard or turn signal switch.
Here is a schematic at a site:
http://www.hammar.dyndns.org/~djhamma/wiring/1968/E7.jpg
gingerbreadman
Only half-baked
5,358
Go ahead, call me cheaky
Aug 25, 2005
  • Aug 25, 2005
start tracing back, First make sure you have a good ground for the tail light assembly. Then follow the power wires back untill you get power.
You own and know how to use a multi meter right?
-gbm-
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Aug 25, 2005
  • Aug 25, 2005
Check all bulbs to see if any are burnt out. One can cause others to not work.
C
cgstang
  • Aug 25, 2005
do your turn signals work?? Everything goes through your turn signal cam, signals, brake lights, and hazards...
Kriek
57
Dallas, TX
Aug 25, 2005
  • Aug 25, 2005
Have you checked to make sure all the grounds are good?
mrmcmillen
43
Carrollton, Texas
Aug 26, 2005
  • Aug 26, 2005
well.....not so much on the multimeter Gingerbreadman.....i have aspirations of learning though......
i did figure out that jacking around with the turn signal lever screws up some stuff and fixes others ....so i'm thinking a $120 turn sigal switch should do the trick....
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
