brake lights
my brake lights won't work....and i'm feelin the need to get the car out of the garage.....help me!
i have replaced the brake light swith....that wasn't it.
i tested the power going into the brake light swith and coming out of the brake light swith.....both have power.
my flashers don't work either. front flashers work....dash flashers work....no rear flashers....
i tested the power at the tail lamp too....no luck!
does any one know what the problem could be?
It's different than my '65, but see if you can check the connector coming out of the column for brake/signal light power. Orange/blue (Right) and Green/Orange (Left). If none, then it could be the hazard or turn signal switch.
Here is a schematic at a site:
http://www.hammar.dyndns.org/~djhamma/wiring/1968/E7.jpg
well.....not so much on the multimeter Gingerbreadman.....i have aspirations of learning though......
i did figure out that jacking around with the turn signal lever screws up some stuff and fixes others ....so i'm thinking a $120 turn sigal switch should do the trick....
