  • SN95 4.6L Mustang Tech
Brake noise....help!!!
  • Thread starter Thread starter steve44england
  • Start date Start date Jul 5, 2006
steve44england
9
  • Jul 5, 2006
Hi all,
Straight after having a brake test on a roller for its annual MOT test,my 96 GT started a noise from the front brakes when braking.
Its almost like the ABS is working when it shouldn't......doesn't do it every time i brake,and seems to make a noise on every revolution of the wheels.
Has anyone had the same problem?????
Steve
46gtsblown
278
  • Jul 6, 2006
So where in England are you?
I have spent 12 years at RAF Mildenhall.
Anyway I would perform several back to back stops on a quiet road to put some heat into the rotors and clean off the pads.
Depending on the age of the pads I would also look to see how much pad life remains, you may be on the wear indicators.
Dwayne
merc123
420
North GA
Jul 6, 2006
  • Jul 6, 2006
What kind of noise. Gotta be more specific.
D
dannyboy1999
147
Crossville, TN
Jul 6, 2006
  • Jul 6, 2006
could be rotors getting warped, if your abs was jacked you would have rough abrupt stops
steve44england
9
  • Jul 6, 2006
Its almost as if something is knocking or grinding against something else.....as soon as it started I changed the pads.
I'm in Kent.......been to the air display day at Mildenhall a couple of times....great day out!!!
Steve
hognutz
1,940
albany, oregon
Jul 6, 2006
  • Jul 6, 2006
1. how many miles?
2. how were the rotor surfaces when you changed pads?
3. did you check the rotors to see if there was any warpage at all?
steve44england
9
  • Jul 6, 2006
91000 miles.
The disc surfaces were very good,and there was certainly no obvious warping
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
