  • SN95 4.6L Mustang Tech
Brake Noise!
  • Thread starter Thread starter Silvergto2
  • Start date Start date May 17, 2006
Silvergto2
179
UTAH
May 17, 2006
  • May 17, 2006
I had some new brakes put on my car last year in April. For the last 3 weeks, when I first start to brake, I get a sqeaking / squeeling noise for a couple of seconds from the brakes and then it goes away. Is it brake dust or something more serious? Any suggestions to help me stop the noise would be appreciated.
Silvergto2
179
UTAH
May 18, 2006
  • May 18, 2006
anyone?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
May 18, 2006
  • May 18, 2006
whoa last year so you have a little over a year with them i would check the thickness on the pad see how much is left if it less than half i would replace them
T
Torinalth
952
Clayton NC
May 18, 2006
  • May 18, 2006
agreed, i change mine every 4 months... but then i put on around 40k a year on my car. if they are under 1/4" its time to toss em and get new ones/machined rotors.
Torinalth
loosescrew79
313
  • May 18, 2006
Depending on how hard you use the brakes you could wear them down pretty good in a years time. On my truck I go through pads in a little over a year.
inspect them and if they still look close to new, try cleaning them
hognutz
1,940
albany, oregon
May 18, 2006
  • May 18, 2006
I would inspect the pads, rotors, and you floating pins.
they make componds to put on the pads but I have not had as much luck with that as just replacing the pads.
if you brake pads only last a year you either bought the wrong pads IMO or yu drive a ton. I am at 65k on my oem pads with no noise and they are not shot yet. aftermarket pads are a gamble sometimes. so work fine others are noisy and produce about 10 times the dust. I would use oem or the more expensive ceramic pads this time if you have a problem.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
May 18, 2006
  • May 18, 2006
i got three years with mine and 32K miles and i have replaced them 3 times on the front teh rears are about to be changed though...... goes to show how hard i drive the car
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,118
224
Massachusetts
May 18, 2006
  • May 18, 2006
Most likely they just need to be regreased.
Apply caliper grease to the pad mounting points and rear caliper pins and anti-squeal to the backing plates of the pads. Should quiet them up.
If the pads are low, you might as well replace them
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Weird noises
  • Shanehanna81
  • Nov 26, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2024
Shanehanna81
