  • SN95 4.6L Mustang Tech
Brake problem??
  • Thread starter Thread starter 2000fordstanggt
  • Start date Start date Mar 29, 2007
2000fordstanggt
404
Westland, MI
Mar 29, 2007
  • Mar 29, 2007
I did my brakes last night and now I've got a problem with them. I have to push the pedal all the way to the floor to basically slow down to a stop. I replaced the left rotor and installed new ceramic pads and I couldn't get one of the caliper bolts off on the right side so I had to just put the new pads on the right side leaving the old rotor on just so I could get my car home and fix the problem the next day.
gunmetal5.0
144
Chico, CA
Mar 29, 2007
  • Mar 29, 2007
Bleed the brakes over again. You more than likely still have bubbles in the line. Bleed them as long as it takes until you no longer do, then recycle the fluid back into the reservoir. Much luck.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 29, 2007
  • Mar 29, 2007
Speed bleeders will help a lot. They are kind of pricey though, I believe they are $6 each and you need four of course. Advance Auto should have them...
gunmetal5.0
144
Chico, CA
Mar 29, 2007
  • Mar 29, 2007
That doesn't sound too pricey at all. Never heard of such a product.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 29, 2007
  • Mar 29, 2007
Oh yeah, its a bleeder with a one way check valve so no air can be sucked back in. Just the fluid is pumped out.
gunmetal5.0
144
Chico, CA
Mar 29, 2007
  • Mar 29, 2007
Very useful.
D
Dragstr05
643
Stafford VA
Mar 29, 2007
  • Mar 29, 2007
If you're just putting on new pads and rotors, you shouldnt have to bleed the brakes. All you should have to do is pump the brakes up initially. I did have one brake job that was like that, but after a couple hard stops the problem went away.
Does the car pull to any side when the brakes are applied?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 30, 2007
  • Mar 30, 2007
why are you guys opening the brake lines to change pads.. this is NOT NEEDED..
only time the brake system should be opened is for parts replacement and for fluid flushing.
2000fordstanggt
404
Westland, MI
Mar 30, 2007
  • Mar 30, 2007
no the car doesnt pull in any direction, and the problem wont go away from quick stops..i tried that the other day. my brake system wasnt opened at all, except from some fluid coming out of the resivor when i pushed the caliper pistons back in.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 30, 2007
#10
  • Mar 30, 2007
  • #10
I just assumed he was flushing his fluid at the same time as he did the pads...
Fluid should be flushed every 2-3 years or every 30k miles.
twogts4us
4,188
12
79
Dunedin, FL
Mar 30, 2007
#11
  • Mar 30, 2007
  • #11
Take care in recycling brake fluid...you don't want to put dirty fluid into the system. (What goes in is clear, what comes out, after age, is dark)
04DarkShadowGT
474
Fort Wayne, IN
Mar 30, 2007
#12
  • Mar 30, 2007
  • #12
Advanced auto also sells a one man bleeding kit which works too. I used that when I changed to my 10th anniversary brakes. It was like $7 for the kit and it worked perfectly.
C
cooper
96
#13
  • Mar 30, 2007
  • #13
bleed the master cylnder, sounds like the piston is stuck. hapened to me once.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Mar 31, 2007
#14
  • Mar 31, 2007
  • #14
If it's a brand new rotor and pads, it's going to stop very poorly until the brakes are bedded in.
I remember the first couple times i tried to stop after doing my 13" upgrade. The pedal to the floor would barely stop the car. After i bedded in the rotors, it was biting hard.
Def make sure you change the pads on the other side. Also, if your car is a 2000 and never had the fluid flushed, now would be a good time
Modular_Mike
26
#15
  • Mar 31, 2007
  • #15
Your brakes already have bleeders
Just get someone to work the valve when you pump the brakes.
triggz
1,218
Gadsden, AL
Apr 1, 2007
#16
  • Apr 1, 2007
  • #16
You always should pump the pedal 20 or so times after a pad change to run the caliper pistons out so that the pads are placed correctly against the rotors. There is slack between the pads/rotor and the lack of resistance to build line pressure causes the pedal to go to the floor...
If you still have a sloppy pedal, I would take off the wheel and inspect for slack.
Mike97gt
it doe snot
10,633
Apr 1, 2007
#17
  • Apr 1, 2007
  • #17
did you replace the rear brake pads or the front ones.. If you compressed the rear calipers wrong you may run into issues like this.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
