Brake problem
  • Thread starter Thread starter bnws
  • Start date Start date Oct 24, 2008
bnws
18
  • Oct 24, 2008
Need some help with the following problem. 1965 mustang 289 c.i.d. power drum brakes single bowl master cylinder.
Checked out car before putting back on road after sitting for a while and found leakey wheel cyl's
replaced all for wheel cyl, front pads, new hardware ( spring kits ) all wheels, , blew out all lines , disassambled and cleaned m/c used silicon brake fluid and bled lines
Problem is car pulls severley left when brakes are applied, tracks staight and no pull driving down road.
car was put back on jackstands and all for wheels and drums removed --- every thing looked o.k. primary and secondary shoes correct position, lines where checked for kinks, none found, brakes re-bled
Problem exactly the same car put back on jacks brakes disassembled--front wheel cyl checked (both sides same diam) front drums and wheel bearings switched left to right, brakes bled again---- same exact problem
I dont think the junction block by the master has a residual valve but i,m not certain, any help would be greatly appreciated.
wild70stang
317
  • Oct 24, 2008
Adjust the drums, one side seems to be tighter than the other. The tool looks like this
http://i23.photobucket.com/albums/b378/JBarca/TT Upgrades/DexterAxleUnderSlungBrakeAdjuster.jpg
Just adjust the shoes until it has a slight drag and you should be good. As for the tracking, get your wheels aligned. After I had it done to my car it helped, but it returned soon because my suspension is original (plan to replace it soon).
bnws
18
  • Oct 24, 2008
forgot to mention brakes where adjusted that way and rechecked. car tracks staight down road with no pull untill brakes are applied
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Oct 24, 2008
  • Oct 24, 2008
If the car only pulls when you brake its not the alignment.
If the car pulls the same way every time you brake then your drums need to be adjusted.
rbohm
6,698
550
204
tucson,az
Oct 24, 2008
  • Oct 24, 2008
check the lower control arm bushings to start. next check the adjustment not only on the fronts, but the rears too. third recognize that due to the single bowl master cylinder you are always going to have problems with the brakes pulling to one side no matter what you do. i had the same issue with my mustang, and my falcon. when i swapped to a dual bowl master cylinder that problem virtually went away. the falcon still has a minor pull but nothing annoying.
Brakes are engaged while driving
  • stevetbright
  • May 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 31, 2026
stevetbright
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
