  • SN95 4.6L Mustang Tech
brake problems
  • Thread starter Thread starter 97gtconv.
  • Start date Start date Aug 24, 2006
97gtconv.
244
Lock Haven, PA
Aug 24, 2006
  • Aug 24, 2006
My car is a 97 gt automatic vert with 4-wheel disc brakes.
i have a leak in my right rear brake line... where i think it's called the bleeder screw screws down into the caliper. the brake fluid comes from underneath the brake line where the copper washer is, that seals the brake line to the caliper...
how do i go about removing and re-installing a new one?
another question i have is that my emergency brake isn't holding...it's putting force on the springs and the cable is moving but it's not putting a force or not enough force...i can pull away in drive. i'm not really that worried cause i drive a automatic.
and last question.. my emergency brake is noisy and i mean really noisy..it vibrates like hell and it's annoying..i usual put a jar and fill it up with change to quiet it but it looks like crap doing so...
any help would be great
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 24, 2006
  • Aug 24, 2006
The washer and the banjo bolt are not re-useable. Get new ones and install snugly and that should fix it. You will need to bleed that caliper after.
That is normal.
Sorry, no idea on this one. Someone else will know though
97gtconv.
244
Lock Haven, PA
Aug 25, 2006
  • Aug 25, 2006
i'll try to see if the bolt works and a copper washer. do you know of place that just sells the copper washer? autozone, o'reilly's, and every other place only sells them in a rebuild kit.
i'm about to rip out my emergency brake cause it's so damn annoying....cables handle the whole thing....any chance that's illegal or anything? lol
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Aug 25, 2006
  • Aug 25, 2006
They sell them in the isle. They are in the isle with all the HELP! products. They are in a yellow box full of assorted sizes of copper washers. Just use two that are close in size to what you have.
I've always reused banjo bolts with calipers. It's not exactly a wearable item
You can drive with the e-brake up, but if you park on a slope, yank the e-brake and put the car in nuetral it should stay where it is. If you don't use it, it tends to not work as well. That's why guys with automatics tend to have poor e-brakes while guys with manuals can hold their car on a steep hill with onl;y a few clicks. There are adjusters in the rear calipers for the brake. You must yank the brake up a few times with your foot off the service brake.
As for the noise..that's up to you to locate and fix. Buy a new handle on Ebay. The non-leather GT and V6 ones go cheap
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 25, 2006
  • Aug 25, 2006
Sorry, I just meant the washer is not re-useable...
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
