Brake problems
  • Thread starter Thread starter 69 Mach 393
  • Start date Start date Jun 25, 2007
69 Mach 393
76
SW Missouri
Jun 25, 2007
  • Jun 25, 2007
I Finaly got my car running but the brake lines keep getting air in them.All new calipers new master cylinder and booster new brake lines and no visible leaks. It has four wheel disk brakes but the master cylinder is off of a 69 with power brakes. A porportining valve at the back and a residual valve. Where can the air keep coming from. This car looks awsome can someone tell me how to post pictures.
65 fastback
1,347
Northern VA
Jun 25, 2007
  • Jun 25, 2007
When you say air is getting in, is the pedal getting softer over time? Maybe there is air in there that you just haven't bleed out yet?
Did you bench bleed the Master Cylinder?
What calipers are you running, front and rear?
The best way to post pictures is to open a free account at PhotoBucket.com. Load your pictures there and link them to here.
Tim
69 Mach 393
76
SW Missouri
Jun 25, 2007
  • Jun 25, 2007
I can bleed them and come back 30 minutes later and have air again. I have to pump them but I can get some brake. The front calipers are stock the back I think were off a 98 Mustang. Yes I did bench bleed the master and even took it off and blead it again tonight.
65 fastback
1,347
Northern VA
Jun 25, 2007
  • Jun 25, 2007
OK, so you definately have a leak somewhere. First, I would put it up on jackstands and take off the wheels. Then try to determine where the air is in the brake line, try to isolate your problem to left/rear, right/rear, left/front or right/front.
Add some clear tubing to each bleeder valve and watch for bubbles in the fluid as you open the valve under pressure.
Once you have determined which section of the brake line is leaking, trace it inch by inch back to the MC. Look for any signs of leakage. Also, check the bleeder valve - it's my guess this could be the problem.
Tim
2nd Mustang
2,488
Southern California
Jun 25, 2007
  • Jun 25, 2007
How are you bleeding the lines?
69 Mach 393
76
SW Missouri
Jun 26, 2007
  • Jun 26, 2007
Just pumping them up and then releasing them.And the air will be in all lines. Master cylinder maby.
2nd Mustang
2,488
Southern California
Jun 26, 2007
  • Jun 26, 2007
Do a search on bleeding techniques.
Basically when you pump the brake pedal, hold it down, open the bleeder screw and do not let the brake pedal up until you've closed the screw. Letting the brake pedal up while the screw is open will suck air back in if you're not careful.
If you have two people, it's a lot easier. A "one man" bleeding kit also works, but make sure the bottle is higher than the bleeder screw which will help keep air out if doing it with only one person.
NasaGT
1,993
Virginia
Jun 26, 2007
  • Jun 26, 2007
Thats good advise, took me awhile to figure out why I had always has a soft pedal using a one-man kit. I was putting the bottle on the ground.
65 fastback
1,347
Northern VA
Jun 29, 2007
  • Jun 29, 2007
Did you get your brake issue resolved, yet?
Tim
69 Mach 393
76
SW Missouri
Jul 6, 2007
#10
  • Jul 6, 2007
  • #10
We are still looking for the brake problem. The air is in all 4 brakes and I do know how to blead the brakes. Has anyone done this conversion and did you use a stock master cylinder. Could the master cylinder be the problem.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 7, 2007
#11
  • Jul 7, 2007
  • #11
That is most likely your problem. Get a friend that knows how to do this to help you and see whats going on. Another option is to buy some speed bleeders from the parts store. Also, go read up on proper brake bleeding techniques.
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
