Brake proportioning question...
  • Thread starter Thread starter TobyGaff
  • Start date Start date Jan 9, 2004
TobyGaff
211
Indianapolis
Jan 9, 2004
  • Jan 9, 2004
I am sure this has been asked before, but I couldn't find it in the search...
I have a 65 with a manual drum/drum setup. I want to upgrade to a dual master cylinder and I have been told that the master cylinder from a 69 is a direct bolt in.... however, I know that the 69 came with a disk/drum setup. Can anyone tell me what proportioning valve I need to get in order to make this setup work?
Thanks.
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jan 9, 2004
  • Jan 9, 2004
Ford installed a metering valve 10psi that mounts near the distribution block in the rear brake line. The function of this valve was to keep some pressure on the rear brakes so that the pedal wouldnt be mushy. I had to replace mine this summer, www.mpbrakes.com sells the valve for around 25.00. They can answer questions on brake components, they were very helpful to me. By the way, do not install the adjustable proportioning valve you see in magazines, it is designed to lock the front brakes by turning a knob, usually for racing applications. I almost made the mistake of thinking that was correct for my '68. Hope this helps.
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
Jan 9, 2004
  • Jan 9, 2004
Go to this thread where this was recently discussed...
http://forums.stangnet.com/showthread.php?t=408838
rbohm
6,698
550
204
tucson,az
Jan 9, 2004
  • Jan 9, 2004
use a 67 drum/drum master cylinder, and use the 65 pushrod instead of the longer 67 pushrod.
TobyGaff
211
Indianapolis
Jan 9, 2004
  • Jan 9, 2004
That is the thread that I was looking for. Thanks for your help guys, I really appreciate it.
chepsk8
2,203
Easton, PA
Jan 9, 2004
  • Jan 9, 2004
Masterpower Prop valve
I used the MP distribution / Proportioning valve in Chepie, works great.
The hot ticket for you is to find a Maverick with manual brakes, disc front. The MC bolts right in, and also use the prop valve and needed lines. From what I hear, almost a bolt-in.
monk302
742
New Jersey
Jan 9, 2004
  • Jan 9, 2004
What year Maverick??
chepsk8
2,203
Easton, PA
Jan 9, 2004
  • Jan 9, 2004
Pretty sure 75-77 with the front disc brakes.
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
