brake question 04 cobra
gilscobra
ok might sound dumb but how to i get the front rotors off i pulled the calipiars off should the rotors knock off or do i have to undo the lugs from inside the rotor? working on this sucker at my apt one wheel at a time and getting pissed. any help would be great.
Well if you've already removed the calipers and pads the next thing to remove are the anchor plate bolts (see attachment 1). Then remove the keepers (see attachment 2). The disc should come off. You may need to spray some penetrating oil in and around the studs and let it sit. Some gentle tapping with a rubber mallet will also help.
U.M.
ok i am talking about the front rotors. the rear have 2 bolts that hold on the caliper then 2 bolts that hold on the bracket the pop the clips and the rotor came right off. the front only have 2 bolts that hold the caliper and bracket on that is off and the clips are off and the front isnt budging any thoughts????
