Brake Question... Pads/bearings
Rockin302
236
California
I'm going to be performing a front brake replacement (rotors/pads/bearings) and was wondering if I'll need those special bearing cup removing(ie. D80L-927-A , T77F-1102-A etc.) or installation tools( T73T-1217-A) to get the job done, or, can I use a punch tool of some sort instead?
Also, anyone recommend a nice set of pads?
It's for a 1990 LX 5.0 Notch.
Thanks!!
You need...
C-clamp (for depressing the master cyl), Star bit (don't remember what size), hammer... oh and the lug wrench. And someone there to bleed the brakes for ya, or go to a parts store and there's a special valve for that that's cheap.
Nothin' to it :nice:
No real special tools needed. Of course "special" tools sure make it easier. I really don't know what to tell you, it's simple, but then agian there are a lot of steps that can made a huge difference.
I've done brake jobs on my other car(non-mustang) but there was no bearing in the rotor.
So what I really need to know is how to get out the bearings in the mustang. I have the clamp and everything else(torx bit etc.), vacuum bleeder, to remove the caliper and bleed the brakes.
Thanks again
Yeah, just pop that cover off with a screw driver. Then there's a nut with a cotter pin holding it in. The first bearing falls right out after the nut is taken off, and then you take the rotor off. The next bearing falls right out and then you've got the seal that comes right off- easiest brake job you'll ever do! Good Luck! :)
I'm glad i read this thread. I think that's something im gonna have to do very soon. Makes me feel better that something is easy on this car (btw, i have done two heater cores, so most of you probably know what i am talking about). Oh, just a question. Does anybody know of any Disc brake conversions for the rear of a Fox body?
Maybe I didn't word my question correctly. I know the bearings will fall right out but what about the bearing cups/race that are wedged inside the rotor? I probably need a puller of some sort or use a punch and slowly tap them out? Do I re-use those cups?
