Brake Question
  • Thread starter Thread starter tdj7777
  • Start date Start date Mar 31, 2005
tdj7777
139
Camillus, NY
Mar 31, 2005
  • Mar 31, 2005
I have a 89 lx. I ordered calipers for a 86 svo, braided front lines, and matching ceramic pads. Where can I find a braided line for the rear? I don't plan to put disc brakes on the rear. There are two 93 cobra mc's listed at Advance auto parts, Raybestos MC390125 MC Assembly pg plus w/ power brakes @ $98.99 and Bendix 12669 1" four wheel disc brakes @ $66.96 which do I need? I understand that I also need a mc conversion kit, what is in it, where to buy it, and do I need anything else? Also, what are steel side pin bushings and do they come on the calipers w/ steel piston? What rotors do I need to buy? Looking for drilled and slotted, but need to know if I can order for an 89 or do they have to be for a 86? Are they the same? Thanks.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 31, 2005
  • Mar 31, 2005
See http://www.svo73mm.cjb.net/ for brake help.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Mar 31, 2005
  • Mar 31, 2005
tdj7777 said:
Also, what are steel side pin bushings and do they come on the calipers w/ steel piston? .
No, you'll have to order those from www.maximummotorsports.com
Did you convert to 5-lug? If you have 4-lug wheels still just get rotors for 87-93.
Fox brakes suck and you really should stick with a solid rotor, not anything crossdrilled or slotted. Removing mass from the rotor just makes it way more prone to warping. I know a lot of guys do it for looks...especially in thin spoked wheels, but when it comes to fox rotors, they already suck.
M
mpswirl
18
  • Apr 1, 2005
if you go to summit racing you can order braided lines cause i just did and it came with 2 fronts and 1 center rear
tdj7777
139
Camillus, NY
Apr 1, 2005
  • Apr 1, 2005
Stayed with the 4-lugs. I changed my mind and ordered the mc from a 94 gt from advance auto parts and the conversion kit from maximummotorsports. Advance had the ceramic pads listed, but then showed them as not carried when I ordered. Anyone know where to find ceramic pads?
Brakes Sealant for passenger side brake line fitting? (Weatherhead 7828)
  • dan50
  • Nov 9, 2025
Fox 5.0 Mustang Tech Nov 12, 2025
dan50
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 21, 2026
keel
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
