  • SN95 4.6L Mustang Tech
Brake rattle
  • Thread starter Thread starter LaserSVT
  • Start date Start date Feb 22, 2008
LaserSVT
3,548
233
Feb 22, 2008
  • Feb 22, 2008
So my front brakes rattle like crazy and I figure its cause they dont have the anti-rattle clips on them. Not sure as I have not pulled them apart but seems logical. Are they part of the pads and I gotta do new pads or can they be purchased seperatly. BTW this is for my 96 Cobra.
blurred10
12
Spring, Tx
Feb 22, 2008
  • Feb 22, 2008
I beleive the clips are part of the pads. If you order aftermarket pads, a lot of them don't come with the clips so you have to re-use the old ones. Sometimes people mistakenly throw the old clips out with the old pads. This is what must have happened with the previous owner of my stang. I was doing some work under the car and while inspecting I found my calipers had a bit of play and would clunk when moved. I had been searching for the cause of this horrible noise for quite some time. After a bit of research I found I was missing the anti-rattle clips that hold them in place.
http://forums.stangnet.com/showthread.php?t=667332
After a bit of searching I found a cobra brake hardware kit at O'Reilly Auto Parts that included the pins, e-clips, and anti-rattle clips for both front sides for about $6. The install was a cinch and cured the problem!
LaserSVT
3,548
233
Feb 22, 2008
  • Feb 22, 2008
Just called O'Reillys and they will have them in tomm. and they were $10 for the whole kit like you got. Guess there was inflation
TheBocSez
652
Converse, TX
Feb 23, 2008
  • Feb 23, 2008
Im hoping you just solved my problem too.
By brakes rattling, do you mean in reverse?
My brakes make a horrible rattling noise, but only when I am backing up. The last owner replaced the pads before I bought it so maybe this is the issue for me too.
What does the anti-rattle clip look like and where would I find it at on the car?
LaserSVT
3,548
233
Feb 24, 2008
  • Feb 24, 2008
Where the hell is Converse? IDK what they look like since mine are gone and you will find it on the brakes im guessing Go to OReilys and ask to see the hardware kit for the fron brakes and that will let ya see them and if you dont need them you could always return the parts. I searched for ya and could not locate a picture, sorry
TheBocSez
652
Converse, TX
Feb 24, 2008
  • Feb 24, 2008
Converse is NE of San Antonio.
Does the noise and time it occurs sound similar to your situation?
blurred10
12
Spring, Tx
Feb 24, 2008
  • Feb 24, 2008
Here is a photo that someone posted in another thread. The clip is located under the pin in the photo.
This is the thread I found it on:
LaserSVT
3,548
233
Feb 24, 2008
  • Feb 24, 2008
I hear mine when going over even bumps on the road. If I gently apply the brakes it goes away. It sounds like two metal surfaces rattling against each other
TheBocSez
652
Converse, TX
Feb 26, 2008
  • Feb 26, 2008
thanks for the pic, ill check mine on my days off this week and see if that could me my issue too.
SilverBullet00
1,150
Wichita, KS
Feb 26, 2008
#10
  • Feb 26, 2008
  • #10
I know when I changed my rears last year my clips broke, and the damn things rattled HORRIBLY bad. I finally broke down and bought OEM pads that came with the clips- never had a problem since.
TheBocSez
652
Converse, TX
Feb 26, 2008
#11
  • Feb 26, 2008
  • #11
The person that I bought my car from did a Cobra brake upgrade on the car and changed the pads to Autozones more expensive "performance" pad. He said thats when he noticed the noise start so maybe the pads he put in didnt come with them either.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Feb 26, 2008
#12
  • Feb 26, 2008
  • #12
The Cobra brakes don't have anti-rattle clips... if you are talking about the front ones anyways. That metal piece on the left is a your pads are worn out noise making device. When your pads wear down enough it starts to scrape on the rotor and makes an abnormal (annoying as hell) sound when braking. I'm surprized how many people DON'T notice the difference and just run their stuff into the ground.
The rears have these metal clips that go on the top and bottem of the pads and keep them nice and snug (top to bottem) in the caliper bracket. I would guess thats what you mean by anti-rattle clips ?
Otherwise I would think you guys are talking about the shims which go on the back of the pads. I usually buy Centric Parts brand pads which comes with shims already on the pads.
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
