I had the brakes on my 83 swapped to 88 mustang for the bigger rotor this morning. Everything is weird on it after that. Replaced the spindle,caliper,brakes,brake hose,struts,bearings. The problem is that the steering is so loose that when i barely turn left or right it keeps turning by itself and will go all the way till it stops,Also seems like i have a bigger turning radius. When i hit a bump it wants to go out of control left or right what is up? The tires squeal for every turn i make. The dust shield is rubbing on the rotor i think. Another thing is that the rotor doesnt spin freely when i move it there is tension on it How do i fix this? The steering used to be tight. I dont know if i need to change the rack and pinion is this the same on all mustangS? 79-93 Thanks in advance
