Here is the deal
Just swapped my 4 drums to a 4-disc setup.
I used the original distribution block to feed the front brakes and capped off the rear of the block.
I ran the MC to an adjustable prop valve for the rear discs.
The brakes work fine.
I was driving around the other night and my Brake warning light came on.
Brakes worked with no problems.
I bled the brakes and there was no air in the lines.
The next day the light came on and off every now and then.
My guess is that the distribution block is getting fooled because there is no pressure going to the rear of it since I bypassed it strait to an adjustable prop valve.
Is there another problem that I am not seeing?
Are my brakes fine?
Should I just disconnect the warning light?
Thanks,
Are my brakes fine?
Thanks,
