Brakes Brakes: Hard/Short Then Long/Squishy/Soft Underfoot
Eulers
57
PROBLEM STATEMENT:
1). Want to achieve consistent feel at the brake pedal
2). Most times the pedal is squishy, soft. Other times, the pedal is short and moves only 3/4" underfoot but still with good power and great feel and modulation. This phenomenon will occur multiple times during any given drive on the road.
WHAT I'VE DONE AFTER THIS PHENOMENON STARTED in an attempt to achieve consistent brake feel:
  • Inspected rear slave cylinders for leaks
  • Flushed brake fluid
  • Repeatedly bled all four brakes
  • Replaced the Master Cylinder
  • Bench bled the Master Cylinder
  • Replaced the rubber flex lines with Aeroquip performance hose lines
None of these five procedures has made any difference. Any suggestions appreciated.
Sticky wheel cylinders will do that on stock brakes. When they don't move correctly at both ends it'll make the pedal feel harder.
I think everyone should have a temperature gun. It's one of the best tools for diagnosing brake issues. You want one that goes up to at least 900 degrees so you can check exhaust manifold tubes for proper combustion burn ( that's a whole different subject ).
The rear drums should be the same temp side to side...so should the front rotors. Sticking calipers, brake pads, caliper pins, and collapsed hoses usually cause a higher temperature on that wheel. Incorrectly adjusted rear brakes, sticking wheel cylinders, and sticking brake shoes usually cause low temperature readings.
Reactions: Eulers
Yes. It is a totally stock brake set up (with the exception of the hoses). I do have a temperature gun (Harbor Freight infrared unit).
So now, do I infer the procedure to be:
  1. Bring brakes up to temperature with a half dozen emergency stops from 30 mph.
  2. Hope that the alternating hard/soft pedal phenomenon occurs
  3. Upon the final emergency stop, pull over to the side of the road and take infrared temperature readings at each wheel
  4. Disassemble the low temperature rear wheel brake and dissassemble the high temp front corner. Polish & grease sliding surfaces. Reassemble. Retest
Something like that procedure?
THanks.
Yes, almost exactly like that. The best way is to get them hot by driving like you normally would. Slow moderate brake pressure will show signs easier than stabbing the brakes. Pushing the brakes hard can apply enough pressure to make a sticking cylinder push out both sides...negating the test.
Reactions: Eulers
Thanks for the confirmation and your reply!
Reactions: 90sickfox
I'm a mechanic by trade. It isn't uncommon now days to get a bad master cylinder brand new in the box. I don't know if it has to do with time sitting on the shelf but we've run across a few on older cars.
