  • SN95 4.6L Mustang Tech
brakes question
  • Thread starter Thread starter kstng50
  • Start date Start date Jul 19, 2006
kstng50
68
South Jersey
Jul 19, 2006
  • Jul 19, 2006
When I push my brakes in when stopped there is this squeaking sound like a rusty spring or something being strecthed. It is not the brakes I just replaced them. Do you think I need to bleed the brakes? Or is there anything else you think it could be?
02FastblackGT
64
Tucson, AZ
Jul 19, 2006
  • Jul 19, 2006
I know that everyone suggests to bleed the brakes after changing the pads. Also, I hear that bleeding the master cylinder is a good way to go as well. However, I'm not sure if the "squeaking" noise could be fixed my bleeding the brakes. It sounds like something mechanical. However, I know that my brake pedal makes a little squeaking noise when pushed in, but nothing serious.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 19, 2006
  • Jul 19, 2006
a squeaking sound ould not come from a bleeding issue. it would be somethine rubbing against something else. i would take the brakes back apart and check everything out and make sure nothing is rubbing.
R
Red2000GT
2,450
Regina,Sask.Canada
Jul 19, 2006
  • Jul 19, 2006
Did you reinstall the anti-rattle clips? If not that will cause a noise like that.
Cantslowdown
502
Mt.Home AR!
Jul 19, 2006
  • Jul 19, 2006
Where is the sound coming form is it the back are the front?
N
Nice1Ford
15
  • Jul 19, 2006
I wonder if the problem I'm having is the same thing. When I push the pedal it feels kind of rough and makes what sounds like a squeezing noise and I can also hear a similar noise coming from the brakes if I push it when I'm stopped. What is this?
sunburstgold
58
  • Jul 20, 2006
Did you put anti seize on any place where there would be metal to metal contact like caliper to caliper bracket?
kstng50
68
South Jersey
Jul 20, 2006
  • Jul 20, 2006
it sounds like it might be coming from the pedal itself. I need to get someone to push on them and let me listen by the brakes. Everytime i have someone around it doesnt make the noise though. It made the noise before i did the brakes so i thought it might be the brakes so i replaced them. yea i did put anti seize on it too. maybe this is just a reason to buy some bigger better brakes.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:17 AM
keel
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
