Breaks are squealing, car is fairly new.........
vipergts281
Mr. Metrosexual
2,503
Probably driving somewhere.
I currently have just over 8,200 miles on my car now. When coming to stop, my brakes squeal. I noticed this started happening at around 6,000 miles. Is there any reason why this is happening. They can't possibly need to be replaced already, can they. I do understand dirt can cause breaks to squeal, but I do not believe that is what is causing this.
Any insight on this? Add this to the list I guess. :rolleyes:
Thanks. :cheers:
vipergts281:
I suggest you try the Hawk Performance burnishing procedure:
1. Make 6 to 10 stops from approx. 30 to 35 mph, applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approx. 40 to 45 mph.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
5. After Step 4, your new brake pads are ready to use.
Give it a shot and let us know if this helps (please).
Sometimes a piece of material missing from one of the pads can cause a squeal and so can pads that are actually loose in the caliper ... I'd start looking there. Your car is so new I wouldn't even screw with it unless you like to check that type of stuff yourself.
I only have a little over 26k miles on mine and my pads are probably about 50% yet or better. I haven't had mine off the car yet and most of my experience was with GM brakes in the past. Some people use that blue spooge on the back of pads to quiet them (I never have). When I installed pads before I used to make sure they fit really tight in the caliper by bending the metal ears on the pads and then squeeze them into place with channel locks. Loose pads can vibrate and make noise, that's what I was referring to above. You can also check the anti-rattle clips too and make sure they're tight ... if we even have them? :shrug: Like I said I never had mine apart yet and I'm more familiar with GM. Hope that helps some, good luck.
Thanks for the replies so far guys.
It is my front brakes and it does it only when I am on them. Not after I let my foot off.
I'll be the first to admit, I am not easy on my brakes. But I see no reason why they would be worn out at such low mileage.
nyuk98gt- Thanks for the tips. But shouldn't I only do that with new brakes? I know it won't hurt my breaks, but I don't think that will do anything. :shrug:
I guess I'll have Ford look at them when I take my car in to have my seat back replaced and radio fixed. I know what to look for, but I really don't feel like jacking my car up and taking my wheels off and then looking at my brakes.
Thanks guys. :cheers:
