- Aug 13, 2003
- 52
- 0
- 0
Gentleman,
Just got a nice set of cobra valve covers and was
wondering the best way to install. One of them has
about a 1.5" breather tube on it, while other is flush.
My original setup has a hose going from drivers side valve
cover under carb to intake. The passenger side had a cap
on it with a 2" hose connected to nothing. It had an aftermarket
open airfilter. I now have an OEM airfilter.
Do I install the valve cover with no tube onto the driver side
and run that into the intake, then install the cover with a breather
tube on passenger side and put a hose to the air cleaner? I assume
the PCV valve is in line to the intake, right?
Any help on an effective, emissions legal setup would be appreciated.
If you have a pic of your engine that would probably tell the story.
thanks
andy
thanks
andy
I always wondered If
when you have a Cam with a kinda loopey idle...it might cause a problem with the correct fuction of the pvc?
what do you think?
